[MapServer-users] Ubuntu versions for MapCache?
    Big-Edd
    bigedd at gmail.com
    Thu Feb 13 23:35:02 PST 2025
By the way: This is version 24.04 of Ubuntu.
Managed to get it going with this..  ..
sudo apt install \
git \
cmake \
apache2 \
apache2-dev \
libaprutil1-dev \
libapr1-dev \
libpng-dev \
libjpeg-dev \
libcurl4-gnutls-dev \
libpcre3-dev \
libpixman-1-dev \
libfcgi-dev \
libgdal-dev \
libsqlite3-dev \
libtiff-dev \
libdb-dev \
liblmdb-dev \
-y
Saw this with make. Does it matter? ..  ..
$ make
[  1%] Building C object CMakeFiles/mapcache.dir/lib/axisorder.c.o
..  [SNIP]  ..
[ 21%] Building C object CMakeFiles/mapcache.dir/lib/cache_rest.c.o
/home/eddie/mapcache/lib/cache_rest.c: In function ‘_put_request’:
/home/eddie/mapcache/lib/cache_rest.c:240:3: warning: ‘CURLOPT_PUT’ is
deprecated: since 7.12.1. Use CURLOPT_UPLOAD [-Wdeprecated-declarations]
  240 |   curl_easy_setopt(curl, CURLOPT_PUT, 1L);
In file included from /home/eddie/mapcache/lib/cache_rest.c:35:
/usr/include/x86_64-linux-gnu/curl/curl.h:1281:3: note: declared here
 1281 |   CURLOPTDEPRECATED(CURLOPT_PUT, CURLOPTTYPE_LONG, 54,
[ 22%] Building C object CMakeFiles/mapcache.dir/lib/cache_riak.c.o
..  [SNIP]  ..
[100%] Built target mapcache_detail
Further along: I am now stuck on mapcache.conf (for Apache >= 2.4).
Instructions show this..  ..
<IfModule mapcache_module>   <Directory /path/to/directory>
Require all granted   </Directory>   MapCacheAlias /mapcache
"/path/to/directory/mapcache.xml"</IfModule>
Where is the "/path/to/directory" located?
Do I use one that is already one the system somewhere?
Or do I need to create one? Maybe like this?..  ..
/var/www/mapcache
Cheers,
Eddie.
On Fri, 14 Feb 2025 at 13:26, Big-Edd <bigedd at gmail.com> wrote:
> Hello,
> I begun following instructions here..  ..
> https://mapserver.org/mapcache/install.html
> This is what I see when attempting to install the required, recommended
> and optional packages..  ..
> $ sudo apt install -y \
> git \
> cmake \
> apache2-threaded-dev \
> libpng12-dev \
> libjpeg62-dev \
> libpcre3-dev \
> libpixman-1-dev \
> libfcgi-dev \
> libgdal1-dev \
> libsqlite3-dev \
> libtiff4-dev \
> libdb4.8-dev \
> liblmdb-dev \
> Reading package lists... Done
> Building dependency tree... Done
> Reading state information... Done
> Package libdb4.8-dev is not available, but is referred to by another
> package.
> This may mean that the package is missing, has been obsoleted, or
> is only available from another source
> Package libpng12-dev is not available, but is referred to by another
> package.
> Package libtiff4-dev is not available, but is referred to by another
> package.
> However the following packages replace it:
>   libtiff-dev
> E: Unable to locate package apache2-threaded-dev
> E: Package 'libpng12-dev' has no installation candidate
> E: Unable to locate package libgdal1-dev
> E: Package 'libtiff4-dev' has no installation candidate
> E: Package 'libdb4.8-dev' has no installation candidate
> Cheers,
> Eddie.
> On Fri, 14 Feb 2025 at 09:38, Big-Edd <bigedd at gmail.com> wrote:
>> And where MapCache 1.14.1 is required, so we compile from source, are all
>> dependencies are covered?
>> On Fri, 14 Feb 2025 at 01:05, Richard Greenwood <
>> richard.greenwood at gmail.com> wrote:
>>> Ubuntu 22.04 has MapCache 1.12.0
>>> Ubuntu 24.04 has MapCache 1.14.0
>>> On Thu, Feb 13, 2025 at 1:38 AM Big-Edd via MapServer-users <
>>> mapserver-users at lists.osgeo.org> wrote:
>>>> Hello,
>>>> Which LTS versions of Ubuntu are known to run MapCache, without the
>>>> need to add third party repositories, or manually download packages?
>>>> Cheers,
>>>> Eddie.
>>>> _______________________________________________
>>>> MapServer-users mailing list
>>>> MapServer-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Richard W. Greenwood
>>> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250214/0ac1b76e/attachment-0001.htm>
More information about the MapServer-users
