[MapServer-users] Ubuntu versions for MapCache?
Big-Edd bigedd at gmail.com
Fri Feb 14 00:22:17 PST 2025
Created /var/www/mapcache and copied mapcache.xml there.
$ cat /etc/apache2/mods-enabled/mapcache.conf
<IfModule mapcache_module>
   <Directory /var/www/mapcache>
      Require all granted
   </Directory>
   MapCacheAlias /mapcache "/var/www/mapcache/mapcache.xml"
</IfModule>
$ sudo apachectl restart
[sudo] password for eddie:
AH00526: Syntax error on line 5 of /etc/apache2/mods-enabled/mapcache.conf:
postgresql dimension support requires POSTGRESQL support to be built in
Cheers,
Eddie.
On Fri, 14 Feb 2025 at 15:35, Big-Edd <bigedd at gmail.com> wrote:
> By the way: This is version 24.04 of Ubuntu.
> Managed to get it going with this..  ..
> sudo apt install \
> git \
> cmake \
> apache2 \
> apache2-dev \
> libaprutil1-dev \
> libapr1-dev \
> libpng-dev \
> libjpeg-dev \
> libcurl4-gnutls-dev \
> libpcre3-dev \
> libpixman-1-dev \
> libfcgi-dev \
> libgdal-dev \
> libsqlite3-dev \
> libtiff-dev \
> libdb-dev \
> liblmdb-dev \
> -y
> Saw this with make. Does it matter? ..  ..
> $ make
> [  1%] Building C object CMakeFiles/mapcache.dir/lib/axisorder.c.o
> ..  [SNIP]  ..
> [ 21%] Building C object CMakeFiles/mapcache.dir/lib/cache_rest.c.o
> /home/eddie/mapcache/lib/cache_rest.c: In function ‘_put_request’:
> /home/eddie/mapcache/lib/cache_rest.c:240:3: warning: ‘CURLOPT_PUT’ is
> deprecated: since 7.12.1. Use CURLOPT_UPLOAD [-Wdeprecated-declarations]
>   240 |   curl_easy_setopt(curl, CURLOPT_PUT, 1L);
> In file included from /home/eddie/mapcache/lib/cache_rest.c:35:
> /usr/include/x86_64-linux-gnu/curl/curl.h:1281:3: note: declared here
>  1281 |   CURLOPTDEPRECATED(CURLOPT_PUT, CURLOPTTYPE_LONG, 54,
> [ 22%] Building C object CMakeFiles/mapcache.dir/lib/cache_riak.c.o
> ..  [SNIP]  ..
> [100%] Built target mapcache_detail
> Further along: I am now stuck on mapcache.conf (for Apache >= 2.4).
> Instructions show this..  ..
> <IfModule mapcache_module>   <Directory /path/to/directory>      Require all granted   </Directory>   MapCacheAlias /mapcache "/path/to/directory/mapcache.xml"</IfModule>
> Where is the "/path/to/directory" located?
> Do I use one that is already one the system somewhere?
> Or do I need to create one? Maybe like this?..  ..
> /var/www/mapcache
> Cheers,
> Eddie.
> On Fri, 14 Feb 2025 at 13:26, Big-Edd <bigedd at gmail.com> wrote:
>> Hello,
>> I begun following instructions here..  ..
>> https://mapserver.org/mapcache/install.html
>> This is what I see when attempting to install the required, recommended
>> and optional packages..  ..
>> $ sudo apt install -y \
>> git \
>> cmake \
>> apache2-threaded-dev \
>> libpng12-dev \
>> libjpeg62-dev \
>> libpcre3-dev \
>> libpixman-1-dev \
>> libfcgi-dev \
>> libgdal1-dev \
>> libsqlite3-dev \
>> libtiff4-dev \
>> libdb4.8-dev \
>> liblmdb-dev \
>> Reading package lists... Done
>> Building dependency tree... Done
>> Reading state information... Done
>> Package libdb4.8-dev is not available, but is referred to by another
>> package.
>> This may mean that the package is missing, has been obsoleted, or
>> is only available from another source
>> Package libpng12-dev is not available, but is referred to by another
>> package.
>> Package libtiff4-dev is not available, but is referred to by another
>> package.
>> However the following packages replace it:
>>   libtiff-dev
>> E: Unable to locate package apache2-threaded-dev
>> E: Package 'libpng12-dev' has no installation candidate
>> E: Unable to locate package libgdal1-dev
>> E: Package 'libtiff4-dev' has no installation candidate
>> E: Package 'libdb4.8-dev' has no installation candidate
>> Cheers,
>> Eddie.
>> On Fri, 14 Feb 2025 at 09:38, Big-Edd <bigedd at gmail.com> wrote:
>>> And where MapCache 1.14.1 is required, so we compile from source, are
>>> all dependencies are covered?
>>> On Fri, 14 Feb 2025 at 01:05, Richard Greenwood <
>>> richard.greenwood at gmail.com> wrote:
>>>> Ubuntu 22.04 has MapCache 1.12.0
>>>> Ubuntu 24.04 has MapCache 1.14.0
>>>> On Thu, Feb 13, 2025 at 1:38 AM Big-Edd via MapServer-users <
>>>> mapserver-users at lists.osgeo.org> wrote:
>>>>> Hello,
>>>>> Which LTS versions of Ubuntu are known to run MapCache, without the
>>>>> need to add third party repositories, or manually download packages?
>>>>> Cheers,
>>>>> Eddie.
>>>>> _______________________________________________
>>>>> MapServer-users mailing list
>>>>> MapServer-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> Richard W. Greenwood
>>>> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250214/d8e3a279/attachment.htm>
More information about the MapServer-users mailing list
