[MapServer-users] Varying use of overviews across Mapserver versions
    Richard Greenwood
    richard.greenwood at gmail.com
    Fri Jan 10 11:10:35 PST 2025
Hi Dylan,
Welcome back. Why do you think the issue is related to the use of overviews
and not something else?
Rich
On Fri, Jan 10, 2025 at 10:50 AM Dylan Beaudette via MapServer-users <
mapserver-users at lists.osgeo.org> wrote:
> Thanks Scott,
> I tried that: md5sums on the GeoTiffs and diff on the .map files confirms
> that they are identical.
> The only difference between these two systems is the version of Mapserver.
> MapServer version 7.2.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
> SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> MapServer version 7.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> The newer version is provided via apt:
> cgi-mapserver                          7.6.4-2build2
>     amd64        CGI executable for MapServer
> Any other leads?
> Thanks!
> Dylan
> On Thu, Jan 9, 2025 at 2:45 PM Scott via MapServer-users <
>> I would do a sanity check first, just to make sure the 2 raster files
>> are truly the same. Try something like:
>> gdalinfo -stats -hist file1.tif
>> gdalinfo -stats -hist file2.tif
>> Then, I would continue with the .map files, to make sure they are the
>> same. Something like:
>> diff serv1.map serv2.map
>> See what falls out.
>> On 1/9/25 13:10, Dylan Beaudette via MapServer-users wrote:
>> > Hi Everyone,
>> > I've got identical GeoTiffs and .map files on two servers with varying
>> > versions of Mapserver that is being used as a TMS. Mapserver 7.2.2 is
>> (I
>> > think) correctly using the overviews while Mapserver 7.6.4 is not.
>> > Here is an example of the same file, tile, and styling applied across
>> > both versions of Mapserver.
>> > # Mapserver 7.2.2:
>> > https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/
>> > ste/
>> taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5
>> https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5
>> > Mapserver 7.6.4:
>> > https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/
>> > ste/
>> https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5
>> > It appears to me that the newer version is either ignoring or
>> > interpreting the overviews differently. Each file has an internal
>> tiling
>> > and overview scheme like this:
>> > Band 1 Block=1766x4 Type=Byte, ColorInterp=Gray
>> >    NoData Value=0
>> >    Overviews: 883x1262, 442x631, 221x316, 111x158
>> > Does anyone have a clue about the differences? Is either version in
>> error?
>> > Thanks, and good to be back on the mailing list after a nearly 15 year
>> > hiatus!
>> > Dylan
>> > _______________________________________________
>> > MapServer-users mailing list
>> > MapServer-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250110/c78179af/attachment-0001.htm>
More information about the MapServer-users
