[MapServer-users] Varying use of overviews across Mapserver versions
Dylan Beaudette
debeaudette at ucdavis.edu
Fri Jan 10 11:30:54 PST 2025
Hi Rich,
Now that is a good question! Perhaps an implied use of those overviews has
changed across versions, or a previously-default mapfile parameter has
changed. We didn't see anything in the changelog, but to be honest, a lot
has changed between versions and maybe I missed something.\
Here is a direct link to the file, in case that is helpful:
https://soilmap4-1.lawr.ucdavis.edu/taxa-grid-tms/taxsubgrp/typic_xerofluvents.tif
Here is a snippet from the mapfile, the same on both machines. Note that we
are using a combination of pattern matching and expressions to select files
and apply a color styling. Perhaps there was an implied change to
"processing" or "use of overviews" directives in the more recent mapserver
version?
MAP
OUTPUTFORMAT
NAME "png"
IMAGEMODE RGBA
DRIVER "AGG/PNG"
MIMETYPE "image/png"
EXTENSION "png"
FORMATOPTION "GAMMA=0.75"
END
STATUS ON
# set the output projection of map images to 'spherical mercator'
used by leaflet maps
PROJECTION
"init=epsg:3857"
END
##### blue 9 from dylan
LAYER
NAME blue9dylan
STATUS ON
DATA "%type%/%name%.tif"
TYPE RASTER
# set the input projection of the source data
PROJECTION
"init=epsg:3857"
END
VALIDATION
"type"
"^taxorder|taxsuborder|taxgrtgroup|taxsubgrp|fm\/gg|fm\/sg$"
"name" "^[a-zA-z_\-]+$"
"minvalue" "^[0-9]{1,3}$"
END
CLASS # NoData Values
EXPRESSION ([pixel] = 0)
STYLE
COLOR "#00000000"
END
END
CLASS
EXPRESSION ([pixel] >= %minvalue% AND [pixel] <= 2)
STYLE
COLOR "#E0F7E1"
END
END
Thanks,
Dylan
On Fri, Jan 10, 2025 at 11:10 AM Richard Greenwood <
richard.greenwood at gmail.com> wrote:
> Hi Dylan,
> Welcome back. Why do you think the issue is related to the use of
> overviews and not something else?
> Rich
> On Fri, Jan 10, 2025 at 10:50 AM Dylan Beaudette via MapServer-users <
> mapserver-users at lists.osgeo.org> wrote:
>> Thanks Scott,
>> I tried that: md5sums on the GeoTiffs and diff on the .map files confirms
>> that they are identical.
>> The only difference between these two systems is the version of Mapserver.
>> MapServer version 7.2.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
>> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
>> SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
>> SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE
>> MapServer version 7.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
>> SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> The newer version is provided via apt:
>> cgi-mapserver 7.6.4-2build2
>> amd64 CGI executable for MapServer
>> Any other leads?
>> Thanks!
>> Dylan
>> On Thu, Jan 9, 2025 at 2:45 PM Scott via MapServer-users <
>>> I would do a sanity check first, just to make sure the 2 raster files
>>> are truly the same. Try something like:
>>> gdalinfo -stats -hist file1.tif
>>> gdalinfo -stats -hist file2.tif
>>> Then, I would continue with the .map files, to make sure they are the
>>> same. Something like:
>>> diff serv1.map serv2.map
>>> See what falls out.
>>> On 1/9/25 13:10, Dylan Beaudette via MapServer-users wrote:
>>> > Hi Everyone,
>>> > I've got identical GeoTiffs and .map files on two servers with varying
>>> > versions of Mapserver that is being used as a TMS. Mapserver 7.2.2 is
>>> (I
>>> > think) correctly using the overviews while Mapserver 7.6.4 is not.
>>> > Here is an example of the same file, tile, and styling applied across
>>> > both versions of Mapserver.
>>> > # Mapserver 7.2.2:
>>> https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/
>>> > ste/
>>> taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5
>>> https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5
>>> > Mapserver 7.6.4:
>>> https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/
>>> > ste/
>>> https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5
>>> > It appears to me that the newer version is either ignoring or
>>> > interpreting the overviews differently. Each file has an internal
>>> tiling
>>> > and overview scheme like this:
>>> > Band 1 Block=1766x4 Type=Byte, ColorInterp=Gray
>>> > NoData Value=0
>>> > Overviews: 883x1262, 442x631, 221x316, 111x158
>>> > Does anyone have a clue about the differences? Is either version in
>>> error?
>>> > Thanks, and good to be back on the mailing list after a nearly 15 year
>>> > hiatus!
>>> > Dylan
>>> > _______________________________________________
>>> > MapServer-users mailing list
>>> > MapServer-users at lists.osgeo.org
>>> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Richard W. Greenwood
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250110/a7029186/attachment.htm>
More information about the MapServer-users
