[MapServer-users] Varying use of overviews across Mapserver versions
    Scott
    public at postholer.com
    Fri Jan 10 12:04:46 PST 2025
This may be a clue.
I gdalwarp'd your typic_xerofluvents.tif to a proper -f COG format and
did stats on both. The block sizes are wildly different. Try making a
proper COG out of your .tif and see if you get the same results.
Block=1766x4, as opposed to Block=512x512
Here's what I'm looking at:
gdalinfo -stats typic_xerofluvents.tif
Band 1 Block=1766x4 Type=Byte, ColorInterp=Gray
   Minimum=1.000, Maximum=95.000, Mean=10.684, StdDev=12.230
   NoData Value=0
   Overviews: 883x1262, 442x631, 221x316, 111x158
   Metadata:
     STATISTICS_MINIMUM=1
     STATISTICS_MAXIMUM=95
     STATISTICS_MEAN=10.684186169509
     STATISTICS_STDDEV=12.229580166735
     STATISTICS_VALID_PERCENT=0.3393
gdalwarp -f COG typic_xerofluvents.tif tst.tif
gdalinfo -stats tst.tif
Band 1 Block=512x512 Type=Byte, ColorInterp=Gray
   NoData Value=0
   Overviews: 883x1262, 441x631, 220x315, 110x157
   Metadata:
On 1/10/25 11:30, Dylan Beaudette wrote:
> Hi Rich,
> Now that is a good question! Perhaps an implied use of those overviews
> has changed across versions, or a previously-default mapfile parameter
> has changed. We didn't see anything in the changelog, but to be honest,
> a lot has changed between versions and maybe I missed something.\
> Here is a direct link to the file, in case that is helpful:
> https://soilmap4-1.lawr.ucdavis.edu/taxa-grid-tms/taxsubgrp/
> typic_xerofluvents.tif <https://soilmap4-1.lawr.ucdavis.edu/taxa-grid-
> tms/taxsubgrp/typic_xerofluvents.tif>
> Here is a snippet from the mapfile, the same on both machines. Note that
> we are using a combination of pattern matching and expressions to select
> files and apply a color styling. Perhaps there was an implied change to
> "processing" or "use of overviews" directives in the more recent
> mapserver version?
> MAP
>          OUTPUTFORMAT
>                  NAME "png"
>                  IMAGEMODE RGBA
>                  DRIVER "AGG/PNG"
>                  MIMETYPE "image/png"
>                  EXTENSION "png"
>                  FORMATOPTION "GAMMA=0.75"
>          END
>          STATUS ON
>          # set the output projection of map images to 'spherical
> mercator' used by leaflet maps
>          PROJECTION
>                  "init=epsg:3857"
>          END
>          ##### blue 9 from dylan
>          LAYER
>                  NAME blue9dylan
>                  STATUS ON
>                  DATA "%type%/%name%.tif"
>                  TYPE RASTER
>                  # set the input projection of the source data
>                  PROJECTION
>                          "init=epsg:3857"
>                  END
>                  VALIDATION
>                          "type" "^taxorder|taxsuborder|taxgrtgroup|
> taxsubgrp|fm\/gg|fm\/sg$"
>                          "name" "^[a-zA-z_\-]+$"
>                          "minvalue" "^[0-9]{1,3}$"
>                  END
>                  CLASS # NoData Values
>                          EXPRESSION ([pixel] = 0)
>                          STYLE
>                                  COLOR "#00000000"
>                          END
>                  END
>                  CLASS
>                          EXPRESSION ([pixel] >= %minvalue% AND [pixel] <= 2)
>                          STYLE
>                                  COLOR "#E0F7E1"
>                          END
>                  END
> Thanks,
> Dylan
> On Fri, Jan 10, 2025 at 11:10 AM Richard Greenwood
> <richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>> wrote:
>     Hi Dylan,
>     Welcome back. Why do you think the issue is related to the use of
>     overviews and not something else?
>     Rich
>     On Fri, Jan 10, 2025 at 10:50 AM Dylan Beaudette via MapServer-users
>     <mapserver-users at lists.osgeo.org <mailto:mapserver-
>     users at lists.osgeo.org>> wrote:
>         Thanks Scott,
>         I tried that: md5sums on the GeoTiffs and diff on the .map files
>         confirms that they are identical.
>         The only difference between these two systems is the version of
>         Mapserver.
>         MapServer version 7.2.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>         SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>         SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
>         SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>         SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>         SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
>         SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>         INPUT=GDAL INPUT=SHAPEFILE
>         MapServer version 7.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>         SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG
>         INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>         The newer version is provided via apt:
>         cgi-mapserver                          7.6.4-2build2
>                        amd64        CGI executable for MapServer
>         Any other leads?
>         Thanks!
>         Dylan
>         On Thu, Jan 9, 2025 at 2:45 PM Scott via MapServer-users
>             I would do a sanity check first, just to make sure the 2
>             raster files
>             are truly the same. Try something like:
>             gdalinfo -stats -hist file1.tif
>             gdalinfo -stats -hist file2.tif
>             Then, I would continue with the .map files, to make sure
>             they are the
>             same. Something like:
>             diff serv1.map serv2.map
>             See what falls out.
>             On 1/9/25 13:10, Dylan Beaudette via MapServer-users wrote:
>              > Hi Everyone,
>              > I've got identical GeoTiffs and .map files on two servers
>             with varying
>              > versions of Mapserver that is being used as a TMS.
>             Mapserver 7.2.2 is (I
>              > think) correctly using the overviews while Mapserver
>             7.6.4 is not.
>              > Here is an example of the same file, tile, and styling
>             applied across
>              > both versions of Mapserver.
>              > # Mapserver 7.2.2:
>              > https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/
>             data1/website/ <https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/
>             mapserv?map=/data1/website/>
>              > ste/
>             taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5 <https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5 <https://soilmap2-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5>>
>              > Mapserver 7.6.4:
>              > https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/
>             data1/website/ <https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/
>              > ste/
>             taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5 <https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5 <https://soilmap4-1.lawr.ucdavis.edu/cgi-bin/mapserv?map=/data1/website/ste/taxa.map&mode=tile&tilemode=gmap&tile=5+12+5&layer=blue9dylan&type=taxsubgrp&name=typic_xerofluvents&minvalue=5>>
>              > It appears to me that the newer version is either
>             ignoring or
>              > interpreting the overviews differently. Each file has an
>             internal tiling
>              > and overview scheme like this:
>              >    NoData Value=0
>              > Does anyone have a clue about the differences? Is either
>             version in error?
>              > Thanks, and good to be back on the mailing list after a
>             nearly 15 year
>              > hiatus!
>              > Dylan
>              > _______________________________________________
>              > MapServer-users mailing list
>              > MapServer-users at lists.osgeo.org <mailto:MapServer-
>              > https://lists.osgeo.org/mailman/listinfo/mapserver-users
>             <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
>     Richard W. Greenwood
>     www.greenwoodmap.com <http://www.greenwoodmap.com>
More information about the MapServer-users
