[MapServer-users] Error advises checking logs, but I am not sure what logs it's referring to
Rob Dennett Rob.Dennett at twdb.texas.gov
Thu Jul 24 07:10:49 PDT 2025
I am using httpd as the web server and have MS_ERRORFILE set to stderr and in /etc/httpd/logs/error_file, I see
stderr: msOGRFileOpen(): OGR error. GetLayer(geom FROM area_type) failed for OGR connection. Check logs.
What logs are being referred to here?
BTW, here's some stuff from the LAYER in the .map file.  Not sure if it's relevant:
    NAME "area_type"
    CONNECTIONTYPE OGR
    CONNECTION "/vsicurl/https://github.com/iamgeodude/testgio/raw/main/area_types.parquet"
    TYPE POLYGON
    STATUS ON
    DATA "geom FROM area_type"
Thanks
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250724/6c0c743f/attachment.htm>
More information about the MapServer-users mailing list
