[MapServer-users] Error advises checking logs, but I am not sure what logs it's referring to
Scott public at postholer.com
Thu Jul 24 07:56:42 PDT 2025
Your parquet file is area_types.parquet (has an 's').
Your DATA is requesting area_type (singular). Is that the correct layer
name?
On 7/24/25 07:10, Rob Dennett via MapServer-users wrote:
> I am using httpd as the web server and have MS_ERRORFILE set to stderr
> and in /etc/httpd/logs/error_file, I see
> stderr: msOGRFileOpen(): OGR error. GetLayer(geom FROM area_type) failed
> for OGR connection. Check logs.
> What logs are being referred to here?
> BTW, here's some stuff from the LAYER in the .map file.  Not sure if
> it's relevant:
>      NAME "area_type"
>      CONNECTIONTYPE OGR
>      CONNECTION "/vsicurl/https://github.com/iamgeodude/testgio/raw/
> main/area_types.parquet"
>      TYPE POLYGON
>      STATUS ON
>      DATA "geom FROM area_type"
> Thanks
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
