[MapServer-users] Error advises checking logs, but I am not sure what logs it's referring to
Rob Dennett
Rob.Dennett at twdb.texas.gov
Thu Jul 24 08:12:12 PDT 2025
Changing that didn't fix the error. Do you have any idea what logs are being referred to in the error_log?
Thanks,
Rob
Sent: Thursday, July 24, 2025 9:58 AM
To: Rob Dennett <Rob.Dennett at twdb.texas.gov>
Subject: Re: [MapServer-users] Error advises checking logs, but I am not sure what logs it's referring to
External: Beware of links/attachments.
Your parquet file is area_types.parquet (plural, has an 's').
Your DATA is requesting area_type (singular). Is that the correct layer
name?
On 7/24/25 07:10, Rob Dennett via MapServer-users wrote:
> I am using httpd as the web server and have MS_ERRORFILE set to stderr
> and in /etc/httpd/logs/error_file, I see
> stderr: msOGRFileOpen(): OGR error. GetLayer(geom FROM area_type) failed
> for OGR connection. Check logs.
> What logs are being referred to here?
> BTW, here's some stuff from the LAYER in the .map file. Not sure if
> it's relevant:
> NAME "area_type"
> CONNECTIONTYPE OGR
> CONNECTION "/vsicurl/https://github.com/iamgeodude/testgio/raw/
> main/area_types.parquet"
> TYPE POLYGON
> STATUS ON
> DATA "geom FROM area_type"
> Thanks
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250724/daee5fc0/attachment-0001.htm>
More information about the MapServer-users
