[MapServer-users] Error advises checking logs, but I am not sure what logs it's referring to
Scott public at postholer.com
Thu Jul 24 08:48:02 PDT 2025
Looking at the file, the layer name is plural, area_types and the
geometry column is 'geometry' not 'geom'.
Run the following from the command line and see what errors you get:
ogrinfo -sql "select geometry from area_types"
/vsicurl/https://github.com/iamgeodude/testgio/raw/main/area_types.parquet
More information about the MapServer-users mailing list
