[MapServer-users] Error advises checking logs, but I am not sure what logs it's referring to
Rob Dennett
Rob.Dennett at twdb.texas.gov
Thu Jul 24 11:27:50 PDT 2025
I got an error trying to run that command:
ERROR 4: Only read-only mode is supported for /vsicurl
When I ran duckdb at the command line, I was able to run
Select geometry from read_parquet("github.com/iamgeodude/testgio/raw/main/area_types.parquet")
Just fine. Updating the code from geom to geometry in the .map file yields the same error. Are the logs mentioned referring to the error_log I am looking at, or something else?
Thanks
Sent: Thursday, July 24, 2025 10:48 AM
To: Rob Dennett <Rob.Dennett at twdb.texas.gov>; MapServer Users <mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] Error advises checking logs, but I am not sure what logs it's referring to
External: Beware of links/attachments.
Looking at the file, the layer name is plural, area_types and the
geometry column is 'geometry' not 'geom'.
Run the following from the command line and see what errors you get:
ogrinfo -sql "select geometry from area_types"
/vsicurl/https://github.com/iamgeodude/testgio/raw/main/area_types.parquet
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250724/100691d7/attachment.htm>
More information about the MapServer-users
