[MapServer-users] MVT Unable to initialize image
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Jul 26 01:44:16 PDT 2025
Also be sure to always define a PROJECTION block for each of your layers.
Have a nice weekend,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2025-07-25 1:42 p.m., Jeff McKenna wrote:
> Hi Mathias,
> What happens if you try in your request: &TILE=0+0+0 (and remove the
> &map.imagetype part) ?
> (that's what I did while documenting steps for the page https://
> mapserver.org/output/tile_mode.html )
> Recent MS4W versions also include an MVT demo as well as a local.map
> test file, so you could:
> - first try in your browser http://127.0.0.1/cgi-bin/mapserv.exe?MAP=/
> ms4w/apps/local-demo/
> local.map&MODE=tile&TILEMODE=gmap&TILE=0+0+0&LAYERS=countries  (you
> should see a map image of the world countries in your browser)
> - then add your OUTPUTFORMAT for MVT into local.map, and then try:
> http://127.0.0.1/cgi-bin/mapserv.exe?MAP=/ms4w/apps/local-demo/
> local.map&MODE=tile&TILEMODE=gmap&TILE=0+0+0&LAYERS=countries&map.imagetype=mvt
> If that fails, you might have to upgrade your MS4W version.
> But if that works, I would then paste your "prescription" layer into
> local.map, and reload that same request in your browser.
> thanks,
> (and thanks for using MS4W)
> -jeff
More information about the MapServer-users mailing list
