[MapServer-users] again msLoadMap: Unable to access file
Atlanta Geek
atlantageek at gmail.com
Mon Mar 10 04:10:10 PDT 2025
Im building a new osm/mapserver. I am running Ubuntu,nginx,mapserver 8.0
I am getting unable to access file.
My top-level config file looks like the following:
$ cat config.conf
CONFIG
ENV
MS_MAP_PATTERN ".*"
MS_DEBUGLEVEL "5"
MS_ERRORFILE "/tmp/mapserver2.err"
MS_MAPFILE "/usr/local/basemaps/osm-default.map"
END
END
$ pwd
/usr/local/basemaps
When I try validation with my map2img I get a different error
$ map2img -m /usr/local/basemaps/config.conf -all_debug 5 -o output.png
msLoadMap(): Regular expression error. Filename validation failed. <be>
The URL looks like tk the following.
http://10.0.0.231/mapserver?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&MAP=%2Fusr%2Flocal%2Fbasemaps%2Fconfig.conf&LAYERS=default&WIDTH=256&HEIGHT=256&CRS=EPSG%3A3857&STYLES=&BBOX=-9079495.967826376%2C3913575.8482010234%2C-8922952.933898335%2C4070118.8821290643
Any guidance would be appreciated.
http://www.atlantageek.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250310/660520a4/attachment.htm>
More information about the MapServer-users
