[MapServer-users] again msLoadMap: Unable to access file
Jan Hartmann
j.l.h.hartmann at gmail.com
Tue Mar 11 04:49:48 PDT 2025
You need to have a configuration file. For Ubuntu this is
/user/local/etc/mapserver.conf. It replaces the CONFIG section in the
mapfile. See:
https://mapserver.org/mapfile/config.html
Jan
On 10/03/2025 12:10, Atlanta Geek via MapServer-users wrote:
> Im building a new osm/mapserver. I am running Ubuntu,nginx,mapserver 8.0
> I am getting unable to access file.
> My top-level config file looks like the following:
> $ cat config.conf
> CONFIG
> ENV
> MS_MAP_PATTERN ".*"
> MS_DEBUGLEVEL "5"
> MS_ERRORFILE "/tmp/mapserver2.err"
> MS_MAPFILE "/usr/local/basemaps/osm-default.map"
> END
> END
> $ pwd
> /usr/local/basemaps
> When I try validation with my map2img I get a different error
> $ map2img -m /usr/local/basemaps/config.conf -all_debug 5 -o output.png
> msLoadMap(): Regular expression error. Filename validation failed. <be>
> The URL looks like tk the following.
> http://10.0.0.231/mapserver?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&MAP=%2Fusr%2Flocal%2Fbasemaps%2Fconfig.conf&LAYERS=default&WIDTH=256&HEIGHT=256&CRS=EPSG%3A3857&STYLES=&BBOX=-9079495.967826376%2C3913575.8482010234%2C-8922952.933898335%2C4070118.8821290643
> <http://10.0.0.231/mapserver?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&MAP=%2Fusr%2Flocal%2Fbasemaps%2Fconfig.conf&LAYERS=default&WIDTH=256&HEIGHT=256&CRS=EPSG%3A3857&STYLES=&BBOX=-9079495.967826376%2C3913575.8482010234%2C-8922952.933898335%2C4070118.8821290643>
> Any guidance would be appreciated.
> http://www.atlantageek.com
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250311/38265ac9/attachment.htm>
More information about the MapServer-users
