[MapServer-users] Configuration of MapCache when you have hundreds of .map files
Richard Greenwood richard.greenwood at gmail.com
Tue Mar 18 08:01:54 PDT 2025
On Tue, Mar 18, 2025 at 7:09 AM Rob Dennett via MapServer-users <
mapserver-users at lists.osgeo.org> wrote:
> Resending this in the hopes of getting some fresh eyes on it.
> Are all parts of the mapcache.xml required, i.e. source, cache, grid,
> etc?  I have MapServer running as a cgi script on Apache and I want to add
> MapCache in order to have cached tiles written to and read from an S3
> bucket.  There are hundreds of .map files on the server machine.  The
> current urls look like
> Https:// <https://mymapserver.our/>mapserver.our
> organization.com/?map=/path/to/example.map&otherparams
> Do I need to create a mapcache.xml with anything more than a source with
> http and a cache, a la
> <mapcache>
> <source name="map-server" type="wms">
> <http>
> <url>https://mapserver.ourorganization.com</url>
> <connection_timeout>30</connection_timeout>
> </http>
> </source>
> <cache name="s3" type="s3">
> <url>
> https://mybucket.s3.amazonaws.com/tiles/{tileset}/{grid}/{z}/{x}/{y}.{ext}
> </url>
> <headers>
> <Host>mybucket.s3.amazonaws.com</Host>
> </headers>
> <id>XXXXXXXXXXXXXXX</id>
> <secret>foobaregrwq1235234532/3245234sadgfwevsd</secret>
> <region>us-east-1</region>
> <operation type="put">
> <headers>
> <x-amz-storage-class>REDUCED_REDUNDANCY</x-amz-storage-class>
> <x-amz-acl>public-read</x-amz-acl>
> </headers>
> </operation>
> </cache>
> </mapcache>
> From stuff I have found online, it seems like you need to have one of
> these per .map file.  Hopefully, that's not the case, but can someone
> please clarify?
> Thanks,
> Rob
The short answers are yes, you probably will need a <tileset> for each
layer and possibly a <grid> shared between layers. And you probably need
all those for each of your .map files. A mapserver .map file can contain
one or more layers. A mapcache tileset can only be one layer, so worst
case, you might need more than one set of mapcache definitions for each of
your .map files.
I'd suggest starting small. Start with one layer that gets a lot of traffic
and get everything working for just that one layer and you'll start to see
why each part is required. A single web app can call mapcache and mapserver
for different layers so you don't need to get all your layers behind
mapcache all at once.
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250318/7e504adc/attachment.htm>
More information about the MapServer-users mailing list
