[MapServer-users] Is there a way to set the document root for .map files?
    Scott
    public at postholer.com
    Thu Mar 20 15:31:06 PDT 2025
Not only is exposing your .map files not a great idea, you should
consider wrapping your mapserv url in a php/python/etc script.
That way you can filter any passed data to see if it's suspect or just
gather stats. More importantly, it hides any info about your backend,
including the name of the mapserv binary. I rename mapserv to a
non-obvious name in cgi-bin and use a wrapper.
In your case, using a wrapper around mapserv would allow you to hard
code one single url for all you apps/client, then the wrapper could
update the url based on customer.
You could also set up a redirect in your web server to redirect all
/cgi-bin/mapserv requests to that wrapper.
Scott
On 3/20/25 14:05, Rob Dennett via MapServer-users wrote:
> Can you expand on the potential security issue posed by using the path
> name?
> Thanks,
> Rob
> *From:* Richard Greenwood <richard.greenwood at gmail.com>
> *Sent:* Thursday, March 20, 2025 1:34 PM
> *To:* Rob Dennett <Rob.Dennett at twdb.texas.gov>
> *Cc:* mapserver <mapserver-users at lists.osgeo.org>
> *Subject:* Re: [MapServer-users] Is there a way to set the document root
> for .map files?
> External: Beware of links/attachments.
> This doesn't exactly answer your question, but directly referencing your
> map file in the URL is discouraged because it's a potential
> security issue. The "best practice" is to create an alias to each of
> your map files. For mapserv >= 8.0 that can be done in the
> mapserver.conf file, for example:
>     MAP
>        foo1 "/path/to/foo1.map
>        foo2 "/path/to/foo2.map
>     END
> or for mapserv < 8.0 it can be done in the Apache config:
>     SetEnv foo1 "/path/to/foo1.map"
> And then "best practice" is to block access to map files on the file
> system with
>     MS_MAP_NO_PATH "1"
> which is done in the mapserver.conf or the Apache conf depending on
> mapserv version.
> If you still want to reference map files in the http request I believe
> they are relative to the mapserv binary (I'm saying this from memory, so
> I might be wrong). So you could put a symlink in your cgi-bin/ to /path/
> to/mapfiles/ but I think that's a terrible idea.
> Rich
> On Thu, Mar 20, 2025 at 9:37 AM Rob Dennett via MapServer-users
> <mapserver-users at lists.osgeo.org <mailto:mapserver-
> users at lists.osgeo.org>> wrote:
>     Is there a way to set a sort of document root for .map files and
>     other files .map files might reference?  For example, my .map files
>     are found at the root of an S3 bucket and we're trying to use an EFS
>     volume instead.  Our URLs currently look like
>     https://www.ourOrg.com/cgi-bin/mapserv/?map=/foo.map&. <https://
>     www.ourOrg.com/cgi-bin/mapserv/?map=/foo.map&.>..
>     Where foo.map lives in the root of the s3 bucket.  With the new
>     system we want, it will live at the root of the EFS volume, but with
>     that volume mounted in a different directory in the docker container
>     where MapServer runs, e.g. /ourOrg_mapserver.  The file system in
>     the container is
>     /ourOrg_mapserver/foo.map
>     There are many existing URLs in our client apps as well as 3rd party
>     customer apps which use the above URL.  Is there a way to set up
>     mapserver so that /ourOrg_mapserver acts like an Apache document
>     root so that existing stuff won't need to change?
>     Thanks,
>     Rob
>     _______________________________________________
>     MapServer-users mailing list
>     MapServer-users at lists.osgeo.org <mailto:MapServer-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-users <https://
>     lists.osgeo.org/mailman/listinfo/mapserver-users>
> Richard W. Greenwood
> www.greenwoodmap.com <http://www.greenwoodmap.com>
More information about the MapServer-users
