[MDAL-Developer] Conda Package
Paul Harwood
runette at gmail.com
Mon Oct 26 08:06:01 PDT 2020
So - as these things work out a couple of days after you raised the
question of putting MDAL on conda I got the story to do that for someone
else.
It turned out that having built the test rig and worked out how to do it -
putting a recipe together for MDAL was literally just a couple of hours!
Especially since if we can get this working. - it is going to save me
another couple of stories I have lined up for later in the month.
So - I have created a recipe for MDAL for conda-forge that is working in
local tests. The next step would be to submitted it. ( for info you can see
the recipe here
https://github.com/runette/staged-recipes/tree/mdal/recipes/mdal)
Before I do that - There are three actions I would need.
ACTION NEEDED ->
1 You need to agree to go ahead. You just raised in casually before. I
cannot see a downside but ...
2 It would probably make sense if you (Peter?) were a maintainer (as well
as me) on the package. For that to happen - you will need to comment your
agreement on the submit PR
3 The recipe will not work without the HDF5 compile fix and since you have
to build conda packages from official tarball releases - you would need to
create a new release including at least that PR.
I can't think of anything that will be needed.
Thanks
Paul
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20201026/720d807a/attachment.html>
More information about the MDAL-Developer
