[MDAL-Developer] Volume intrepretation
Martin Dobias
wonder.sk at gmail.com
Tue Aug 24 02:22:22 PDT 2021
Hi Paul
Probably the best description how the vertical levels in meshes are meant
to work is this QGIS enhancement proposal:
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/158
In short, within one face, if you have N vertical levels, there will be N-1
volumes in between those levels for that particular face. There are two
important considerations that may not be obvious:
1. for each face, the vertical levels may be at different elevations/depths
2. for each face, there could be a different number of vertical levels
MDAL_D_volumesCount() returns _total_ number of volumes, not per-face
number of volumes. Based on all this, the total number of vertical level
entries therefore is "number of volumes" + "number of faces" because for
each face we need that one extra vertical level.
Regards
Martin
On Mon, Aug 23, 2021 at 9:23 PM Paul Harwood <runette at gmail.com> wrote:
> Hello all
> Another question for you. I am looking at an app that converts from
> MDAL DataOnVolume dataset to a voxel-based representation.
> That should not be particularly difficult. However, it has made apparent
> that it is not particularly clear what the "Vertical Levels" data in
> MDAL actually means.
> My first understanding - that since the data values are volumetric the
> "vertical levels" represent the centroid of the volume being measured - is
> slightly undermined by the fact that there are (face count + volume count)
> values in the array which is too many for that interpretation.
> The size of the array suggests that the interpretation should be one of
> layered meshes and the volumes are the spaces between the layers. That is
> fair enough but there is only one value per extruded face cell - when it is
> clear that the extruded face cell is not necessarily parallel to anything
> else. Is this vale then the vertical level of the centroid extruded face
> cell?
> Does anyone have a definitive answer?
> MDAL-Developer mailing list
> MDAL-Developer at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mdal-developer
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20210824/1a22ffa8/attachment.html>
More information about the MDAL-Developer
