[MDAL-Developer] Installing MDAL
Paul Harwood
runette at gmail.com
Tue Oct 3 04:56:13 PDT 2023
Sorry - I just read your email correctly. You said "HDF5 files are still
not readable in *QGIS*".
The conda installation does not add MDAL to QGIS - MDAL is actually built
into QGIS at compile time.
Your problem must be something to do with the QGIS environment. I don't
think that Conda can fix that.
What do you mean by hdf5 files are not readable? What layer format are you
trying and what is the error?
On Tue, 3 Oct 2023 at 08:38, Paul Harwood <runette at gmail.com> wrote:
> You don't have to do anything else, it should work.
> What is the error you are getting?
> On Tue, 3 Oct 2023, 06:32 Maria Ramikh via MDAL-Developer, <
> mdal-developer at lists.osgeo.org> wrote:
>> Hello! I installed the package using conda "conda install -c conda-forge
>> mdal", but hdf5 files are still not readable in QGIS. After installing in
>> conda, do I have to do something else?
>> Maria Ramikh
>> MDAL-Developer mailing list
>> MDAL-Developer at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mdal-developer
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20231003/f8336a38/attachment.htm>
More information about the MDAL-Developer
