[Mobilitydb-dev] Fwd: Como cerraste en issue de MacOS ...
Vicky Vergara
vicky at georepublic.de
Mon Aug 2 08:23:18 PDT 2021
Esteban:
I don't know, I dont know docbook, from my perspective you are the expert
on that.
"make doc" should work in any system So I suggest that you work on this
issue and do it like you are used to do it.
https://github.com/MobilityDB/MobilityDB/issues/116
Then we will try to figure out where the action that will use "make doc"
works:
https://github.com/MobilityDB/MobilityDB/issues/117
As we dont know if it works on any system, later on there can be an action
that gives packagers the availability of grabbing the documentation
For example, generate automatically the documentation as attachments to the
tags:
https://github.com/pgRouting/pgrouting/releases/tag/v3.2.1
Regards
---------- Forwarded message ---------
From: Esteban Zimanyi <estebanzimanyi at gmail.com>
Date: Mon, Aug 2, 2021 at 10:16 AM
Subject: Como cerraste en issue de MacOS ...
To: Vicky Vergara <vicky at georepublic.de>
No se podria hacer lo que estoy tratando con MSYS2 ? Es decir en vez de
hacer
pacman -S mingw-w64-x86_64-postgis
que va a instalar postgis 3, yo compilo postgis 2.5.5 (no encontré un
package msys2 antiguo con esta version)
Instalar las dependencias (por ejemplo)
pacman -S mingw-w64-x86_64-proj
pacman -S mingw-w64-x86_64-json-c
Instalar postgis 2.5.5
wget https://download.osgeo.org/postgis/source/postgis-2.5.5.tar.gz
tar -xvf postgis-2.5.5.tar.gz
cd postgis-2.5.5
./configure --without-raster --without-topology
make
make install
Que te parece de tratar esta idea con el MacOS ?
Prof. Esteban Zimanyi
Department of Computer & Decision Engineering (CoDE) CP 165/15
Universite Libre de Bruxelles
Avenue F. D. Roosevelt 50
B-1050 Brussels, Belgium
fax: + 32.2.650.47.13
tel: + 32.2.650.31.85
e-mail: esteban.zimanyi at ulb.be
Internet: http://cs.ulb.ac.be/members/esteban/
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210802/2a6d222c/attachment.html>
More information about the Mobilitydb-dev
