[Mobilitydb-dev] Fwd: Fwd: Como cerraste en issue de MacOS ...
Vicky Vergara
vicky at georepublic.de
Mon Aug 2 08:47:50 PDT 2021
Esteban:
Ok, the macos Action is there, So the issue I closed.
That it does not work on Macos, because macos formula for postgis is for
postgis 3 is another issue.
Basically the action will tell macos formula makers that MobilityDB can be
executed with the formulas.
Note that unlike other systems like Ubuntu that you can choose from, they
always put the formula of the latest release.
For Mobility to work on Macos it must work with the latest postgis release.
Currently for example for windows, Regina will make a test build, but she
is kind enough to test it with postgis 2.5 that will no longer be
supported.
My personal opinion is that MobilityDB can not give a false impression that
it works for macos as is when its not.
Regards
On Mon, Aug 2, 2021 at 10:29 AM Esteban Zimanyi <estebanzimanyi at gmail.com>
wrote:
> Estaba hablando de "building MobilityDB on MacOS" no de docbook :-( No
> quieres leer de nuevo mi comentario?
Yeah. you are right. I closed 2 issues.
>> Mobilitydb-dev mailing list
>> Mobilitydb-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mobilitydb-dev
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210802/af355c56/attachment.html>
More information about the Mobilitydb-dev
