[Mobilitydb-dev] Instructions for building MobilityDB on Windows with msys2
Esteban Zimanyi
esteban.zimanyi at ulb.be
Wed Sep 8 08:24:00 PDT 2021
Dear Regina & Vicky
We have tested the instructions below for building MobilityDB on Windows
with msys2 and they work on arbitrary machines.
However, while I have already PostgreSQL and PostGIS installed on my
Windows computer, the instructions below reinstall PostgreSQL and PostGIS
on msys2 and build with those versions instead of the already installed
ones.
Can you tell us whether this is the right way to do the build or how we can
improve it ?
Many thanks for your help
Download the msys2 installer from https://www.msys2.org/ and follow the
instructions. In the following we assume that you install msys2 on drive D:
On the MSYS2 MSYS shell run the following commands to install the required
dependencies
pacman -S mingw-w64-x86_64-cmake mingw-w64-x86_64-postgresql
mingw-w64-x86_64-postgis
pacman -S mingw-w64-x86_64-gsl mingw-w64-i686-xz git
Run "MSYS MinGW 64-bit" from Start menu and run the following commands
git clone https://github.com/estebanzimanyi/MobilityDB.git
cd MobilityDB
mkdir build
cd build
git checkout msys2-build
cmake -DCMAKE_BUILD_TYPE=Release -G"MinGW Makefiles" ..
cmake --build .
cmake --install .
You need to define where the databases will reside on your hard disk. In
the following we assume the location D:/msys64/usr/local/pgsql/data. Run
export PGDATA="D:/msys64/usr/local/pgsql/data"
rm -rf $PGDATA # DANGER ! This remove all existing databases in that
directory
initdb
To start the database you need to define the port used by PostgreSQL to
listen for connections from client applications. This is typically 5432
unless you have other PostgreSQL versions installed. On msys2 you can use
the following command to see the ports already in use
netstat -a -o | grep LISTENING
In the following we assume that we use the port 5433. Then issue the
following command
export PGPORT=5433
pg_ctl start
createdb mydb
psql mydb
Now on psql issue the following commands
CREATE EXTENSION mobilitydb CASCADE;
SELECT mobilitydb_version();
You should see something like the following
mobilitydb_full_version
MobilityDB 1.0.0 Beta 3, PostgreSQL 13.3, PostGIS 2.5.5
(1 row)
You are now ready to use MobilityDB !
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210908/295213c8/attachment.html>
More information about the Mobilitydb-dev
