[Mobilitydb-dev] FW: [geos-devel] Problem with ST_FrechetDistance in PostGIS/GEOS
Regina Obe
lr at pcorp.us
Fri Sep 17 21:14:19 PDT 2021
Doesn’t look like Martin’s response made it to mobilitydev list probably because he’s not on the list so forwarding.
From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Martin Davis
Sent: Friday, September 17, 2021 4:09 PM
To: GEOS Development List <geos-devel at lists.osgeo.org>
Subject: Re: [geos-devel] [Mobilitydb-dev] Problem with ST_FrechetDistance in PostGIS/GEOS
Well, it looks like there is a possible bug in the GEOS DiscreteFrechetDistance class. This line:
https://git.osgeo.org/gitea/geos/geos/src/branch/main/src/algorithm/distance/DiscreteFrechetDistance.cpp#L112
should probably be
ca[i][j] = p_ptDist;
And indeed that gives the expected answer of 3.
Working on a fix now, and will file a GEOS issue.
On Fri, Sep 17, 2021 at 10:43 AM Martin Davis <mtnclimb at gmail.com <mailto:mtnclimb at gmail.com> > wrote:
I agree with the analysis that there might be a problem with the Frechet Distance algorithm in GEOS. Although, there is a recent PR against JTS for Frechet Distance with a different codebase, and it produces the same result as the GEOS code. So this is puzzling.
The GEOS code is here: https://git.osgeo.org/gitea/geos/geos/src/branch/main/src/algorithm/distance/DiscreteFrechetDistance.cpp
The JTS code is here: https://github.com/locationtech/jts/blob/ff6476cd8fe4e4ee85304ebc049d05a7cafc3c00/modules/core/src/main/java/org/locationtech/jts/algorithm/distance/DiscreteFrechetDistance.java
MobilityDB can compare with their algorithm and see if there is a bug. Or else provide their source code to allow us to compare?
On Thu, Sep 16, 2021 at 2:09 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
I do get 2.23606 on PostGIS so we are in agreement there.
As to what the right answer is I have no clue and reading math equations gives me a headache.
I’ve added geos-develop to mailing list for comment.
Thanks,
Regina
From: Mobilitydb-dev [mailto:mobilitydb-dev-bounces at lists.osgeo.org <mailto:mobilitydb-dev-bounces at lists.osgeo.org> ] On Behalf Of Esteban Zimanyi
Sent: Saturday, September 11, 2021 4:35 AM
To: mobilitydb-dev at lists.osgeo.org <mailto:mobilitydb-dev at lists.osgeo.org>
Subject: [Mobilitydb-dev] Problem with ST_FrechetDistance in PostGIS/GEOS
Dear Regina
We started the implementation of the discrete Frechet distance in MobilityDB and found out that we obtain a different result than PostGIS/GEOS.
test=# select frechetDistance(tgeompoint '[Point(1 1)@2000-01-01, Point(2 2)@2000-01-02, Point(3 1)@2000-01-03]',
tgeompoint '[Point(1 4)@2000-01-01, Point(2 3)@2000-01-02, Point(3 4)@2000-01-03, Point(4 3)@2000-01-04]');
frechetdistance
3
(1 row)
test=# select ST_FrechetDistance(geometry 'Linestring(1 1,2 2,3 1)',
test(# geometry 'Linestring(1 4,2 3,3 4,4 3)');
st_frechetdistance
2.23606797749979
(1 row)
We used the simple algorithm referenced in the PostGIS manual
https://postgis.net/docs/ST_FrechetDistance.html
and according to our understanding the correct result is 3.
Indeed the matrix of Euclidean distances between a vertex of the first linestring and a vertex of the second linestring is as follows
3.6 2.23 2.23
3.6 2.23 3
2.23 1 2.23
3 2.23 3.6
And the matrix of the computation of the Frechet distance (ca in the algorithm) is as follows
3.6 3 3
3.6 3 3
3 3 3
3 3 3.6
Could you please have a look ? If you confirm that there is a problem I will post a ticket in PostGIS and/or GEOS mailing lists.
Many thanks
Esteban
geos-devel mailing list
geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210918/ef7e596c/attachment.html>
An embedded and charset-unspecified text was scrubbed...
Name: Untitled attachment 00011.txt
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210918/ef7e596c/attachment.txt>
More information about the Mobilitydb-dev
