[Mobilitydb-dev] Help with installation of PostGIS on a brand new machine
Regina Obe lr at pcorp.us
Fri Jun 10 03:26:28 PDT 2022
Try doing without make –j.  I’m not sure that works well in 2.5.  I think there were some bugs in it in earlier.
Also make install as I recall shows where it is installing the targets.  Does it show postgis.control installing?
From: Esteban Zimanyi [mailto:estebanzimanyi at gmail.com]
Sent: Friday, June 10, 2022 1:36 AM
To: Regina Obe <lr at pcorp.us>
Cc: Vicky Vergara <vicky at georepublic.de>; mobilitydb-dev at lists.osgeo.org
Subject: Re: Help with installation of PostGIS on a brand new machine
Alas the problem persists. I have installed version PostGIS 2.5.6. After configure I obtained the following output
  PostGIS is now configured for x86_64-pc-linux-gnu
 -------------- Compiler Info -------------
  C compiler:           gcc -g -O0
  SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
 -------------- Additional Info -------------
  Interrupt Tests:   DISABLED use: --with-interrupt-tests to enable
 -------------- Dependencies --------------
  GEOS config:          /usr/bin/geos-config
  GEOS version:         3.8.0
  PostgreSQL config:    /usr/local/pgsql/12/bin/pg_config
  PostgreSQL version:   PostgreSQL 12.11
  PROJ4 version:        63
  Libxml2 config:       /usr/bin/xml2-config
  Libxml2 version:      2.9.10
  JSON-C support:       yes
  protobuf-c support:   yes
  protobuf-c version:   1003003
  PCRE support:         yes
  Perl:                 /usr/bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       disabled
  PostGIS Topology:     disabled
  SFCGAL support:       disabled
  Address Standardizer support:       enabled
 -------- Documentation Generation --------
  xsltproc:             /usr/bin/xsltproc
  xsl style sheets:     /usr/share/xml/docbook/stylesheet/docbook-xsl
  dblatex:              /usr/bin/dblatex
  convert:
  mathml2.dtd:          /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
esteban at DESKTOP-9FBND60:~/src/postgis-2.5.6$ <mailto:esteban at DESKTOP-9FBND60:~/src/postgis-2.5.6$>
After running the commands
make -j
sudo make install
the postgis.control is still not found
esteban at DESKTOP-9FBND60:/usr/local/pgsql/12$ ls /usr/local/pgsql/12/share/extension/
plpgsql--1.0.sql  plpgsql--unpackaged--1.0.sql  plpgsql.control
I have tested this in my old machine and the new one and the output is similar
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20220610/65c115b3/attachment.htm>
More information about the Mobilitydb-dev mailing list
