[NAS] problem when importing atkis nas data into postgres
Armin Retterath armin.retterath at lvermgeo.rlp.de
Mon Jul 12 04:29:26 EDT 2010
hello list,
after compiling again the import was done. i can't find the problem -
maybe some missing dev packages or the temporal *.resolved.gml and
*.gfs files which ogr2ogr writes could not be overwritten in a secondary
import process.
(installed packages ubuntu 10.04:
postgresql-server-dev-8.4
libxerces-c2-dev
libexpat1-dev
expat
libproj-dev
libgeos-dev
further problem:
the objects are now in the database, but their geometry type is
GEOMETRY - maybe a problem with postgis 1.5?
regards armin
Am Freitag 09 Juli 2010, um 15:56:49 schrieb Frank Warmerdam:
> Armin Retterath wrote:
> > hello list,
> > we tested the import functions with real atkis demo data. a
problem
> > occured while import: the structure was generated, but the
elements
> > was not imported. the datatype in geometry_columns was
GEOMETRY -
> > which qgis doesn't know and may be erroneous.
> > maybe s.o. can help.
> > we put the demo data into following place:
http://www.geoportal.rlp.de/metadata/32370000_5590000_32380000_5600000.xm
> > l
> > download per wget or curl - don't click on the url ;-)
> > test system was ubuntu 10.04
> > postgres 8.4
> > postgis 1.5
> > gdal_trunk from today
> > command from shell:
> > ./ogr2ogr -f "PostgreSQL" PG:"dbname=atkis1nas
> > user=mapbender_user host=localhost port=5433
> > password=mapbender_user" -a_srs EPSG:25832
> > 32370000_5590000_32380000_5600000.xml
> Armin,
> I have tried a similar load command with the file you reference with
good
> success. In particular the command I used was:
>   ogr2ogr -update PG:dbname=nas -a_srs EPSG:25832
> The result appears to be a full set of populated layers, reported by
> ogrinfo as:
> INFO: Open of `PG:dbname=nas'
>        using driver `PostgreSQL' successful.
> 1: ax_historischesbauwerkoderhistorischeeinrichtung (Line String)
> 2: ax_flugverkehr (Polygon)
> 3: ax_einrichtungenfuerdenschiffsverkehr (Point)
> 4: ax_ortslage (Polygon)
> 5: ax_kommunalesgebiet (Polygon)
> 6: ax_bauwerkimgewaesserbereich (Line String)
> 7: ax_strassenachse (Line String)
> 8: ax_platz (Polygon)
> 9: ax_leitung (Line String)
> 10: ax_unlandvegetationsloseflaeche (Polygon)
> 11: ax_flaechebesondererfunktionalerpraegung (Polygon)
> 12: ax_gehoelz (Polygon)
> 13: ax_bahnverkehr (Polygon)
> 14: ax_bauwerkoderanlagefuersportfreizeitunderholung (Polygon)
> 15: ax_gewaesserachse (Line String)
> 16: ax_wohnbauflaeche (Polygon)
> 17: ax_wasserspiegelhoehe (Point)
> 18: ax_bahnverkehrsanlage
> 19: ax_schifffahrtsliniefaehrverkehr (Line String)
> 20: ax_nullpunkt (Point)
> 21: ax_abschnitt (Line String)
> 22: ax_sonstigesbauwerkodersonstigeeinrichtung
> 23: ax_gewaessermerkmal (Point)
> 24: ax_friedhof (Polygon)
> 25: ax_wasserlauf
> 26: ax_strasse
> 27: ax_wegpfadsteig (Line String)
> 28: ax_hoehleneingang (Point)
> 29: ax_naturumweltoderbodenschutzrecht
> 30: ax_landwirtschaft (Polygon)
> 31: ax_flaechezurzeitunbestimmbar (Polygon)
> 32: ax_fliessgewaesser (Polygon)
> 33: ax_netzknoten
> 34: ax_bauwerkimverkehrsbereich
> 35: ax_sportfreizeitunderholungsflaeche (Polygon)
> 36: ax_industrieundgewerbeflaeche (Polygon)
> 37: ax_strassenverkehr (Polygon)
> 38: ax_turm (Point)
> 39: ax_bahnstrecke (Line String)
> 40: ax_gebietsgrenze (Line String)
> 41: ax_fahrwegachse (Line String)
> 42: ax_transportanlage (Point)
> 43: ax_tagebaugrubesteinbruch (Polygon)
> 44: ax_vegetationsmerkmal
> 45: ax_gebaeude (Point)
> 46: ax_strassenverkehrsanlage (Point)
> 47: ax_flaechegemischternutzung (Polygon)
> 48: ax_gewaesserstationierungsachse (Line String)
> 49: ax_wald (Polygon)
> 50: ax_denkmalschutzrecht (Point)
> 51: ax_ast (Line String)
> 52: ax_wohnplatz (Point)
> 53: ax_bauwerkoderanlagefuerindustrieundgewerbe (Point)
> 54: ax_fahrbahnachse (Line String)
> 55: alkis_beziehungen
> 56: ax_stehendesgewaesser (Polygon)
> Of the above, only those with no geometry type in brackets are
declared
> as "GEOMETRY" in the GEOMETRY_COLUMNS table and this is because
they
> contain a mix of geometry types or no geometries at all.  Hmm, on
> examination all the ones I looked at have no geometries and were
> represented in the original NAS file as "None" geometry type.  It
> might be nice to preserve this interpretation in Postgis - a failing
> of the OGR PostGIS driver.
> I'm not sure why you had problems, though you might try using
> -update instead of -f PostgreSQL to indicate loading into an
> existing database (making sure it is clean to start).
> Sorry to not respond in German, but all my knowledge of German is
> built on translate.google.com.  :-)
> Best regards,
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
