[OpenDroneMap-dev] capitalized extensions issue
    Stephen Mather
    stephen at smathermather.com
    Wed Jul 22 18:44:12 PDT 2015
Hi Garret,
That's a clever fix. My only hesitation in accepting that as a pull
request is that currently ODM uses the full resolution images in the
texturing step, i.e. the source folder. The resampling of the images
is to aid in processing the structure from motion portion, and that
resampling is an acceptable compromise for that step, but it's really
nice to keep full resolution for the texturing itself.
Regarding the orthorectification step, if you have GPS ephemeris in
your images, run as
./run.pl --odm_georeferencing-useGcp false
Cheers!
Best,
Steve
On Wed, Jul 22, 2015 at 7:03 PM, Garret W <garretlewis at gmail.com> wrote:
> I was looking into the problem with the capitalized extension errors that
> folks were experiencing early on and I noticed in run.pl that when creating
> the textures rather than pointing to the "job folder" it points to the
> "source folder". So Ive updated that in my forked repo.
> https://github.com/glw/OpenDroneMap/commit/75028d27ec9ce2985b758d37d990fa0c8b5d3229
> In my correction Im assuming that the "job folder" is the folder which
> should be used since these images are "prepped" for processing.
> so far it runs through fine with JPG extensions. outputs the texture obj. It
> fails on georeferencing, but as I understand the current status of the
> project georeferencing is not fully functional.
> Let me know if this is an acceptable solution and I can make a pull request.
> Thanks,
> Garret
> OpenDroneMap-dev mailing list
> OpenDroneMap-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-dev
More information about the OpenDroneMap-dev
