[OpenDroneMap-dev] Image Correction
Stephen Mather
stephen at smathermather.com
Sat May 9 05:44:46 PDT 2015
Alternatively, integrating a generalized version of Alex' work here:
https://github.com/wildintellect/lenscorrection would be welcome.
Cheers,
Best,
Steve
On Sat, May 9, 2015 at 8:42 AM, Stephen Mather <stephen at smathermather.com>
wrote:
> Hi Cole,
> Have you had time to do more with this? With Daryl, Alex, and others
> proposing a python port, perhaps we could integrate it, and do distortion
> correction at the front end of the processing chain for images that require
> it by using this class + a user-built calibration library.
> Thoughts?
> Best,
> Steve
> On Thu, Mar 19, 2015 at 12:58 PM, Stephen Mather <
> stephen at smathermather.com> wrote:
>> It seems that the portion of the CMOS used, or effective chips size,
>> would be different between video and stills, so calibration would be
>> different for video and stills.
>> On Thu, Mar 19, 2015 at 11:51 AM, Alex Mandel <tech_dev at wildintellect.com
>> > wrote:
>>> You don't want a video, you want still images. I can upload some later.
>>> The problem with the video is that it's much lower resolution than time
>>> lapse shots from the same camera and you end up grabbing frames from it
>>> anyways.
>>> Measuring the checkerboard loss from really close up shots is exactly
>>> how I guessed the new sensor size.
>>> Thanks,
>>> Alex
>>> On 03/19/2015 05:41 AM, Cole wrote:
>>> > I was just going to email the list about that. I would like to make a
>>> test
>>> > use case for this. Since the ARDrone is probably not within our
>>> normal use
>>> > case, and I do not own a GoPro, would somebody be able to take a video
>>> of a
>>> > checkerboard pattern (
>>> http://wiki.ros.org/camera_calibration/Tutorials/StereoCalibration?action=AttachFile&do=get&target=check-108.pdf
>>> > and share it. Make sure you pan the camera so every part of the
>>> sensor is
>>> > covered by the pattern in at least one frame. Orientation, skew, etc
>>> does
>>> > not matter. Make sure you get it as some different distances as
>>> well. I
>>> > think we can also calculate the CCD width of the cropped image based
>>> on the
>>> > width of the checkerboard cells.
>>> > The next logical progression in this work would be to take video and
>>> find
>>> > the minimum number of overlapping frames to create a desirable result
>>> > using RANSAC. So if y'all have some aerial gopro video footage with
>>> the
>>> > exact same camera, I would appreciate that as well.
>>> > As the I have a use case for my application with video inside and
>>> outside
>>> > of ROS, I will be posting a test case using the ARDrone, which uses a
>>> > wide-angle camera.
>>> > v/r
>>> > NJK
>>> > On Wed, Mar 18, 2015 at 11:33 PM, Stephen Mather <
>>> > wrote:
>>> >> Very interesting, I'll check it out. I'm thinking through the
>>> implications
>>> >> of no cropping, and while this won't affect matching, it likely will
>>> cause
>>> >> issues at the texturing stage, so a default cropping with optional
>>> no-crop
>>> >> would be useful. I assume a crop will affect the effective CCD width,
>>> so
>>> >> that will need calculated.
>>> >> Is there any sharable wide-angle data for testing this?
>>> >> Thanks,
>>> >> Best,
>>> >> Steve
>>> >> On Tue, Mar 17, 2015 at 4:09 AM, Cole <colek42 at gmail.com> wrote:
>>> >>> I have a image calibration class up at
>>> https://github.com/colek42/TrackIt/blob/master/catkin/src/stabilize/src/calibrate.py
>>> >>> It is working great. I'll add a main function and comments in the
>>> next
>>> >>> day or so and do a pull request. I am using an ARDrone camera, but
>>> this is
>>> >>> agnostic to the type of camera. There is no cropping done, so the
>>> edges
>>> >>> are curved with a black background. If it needs to be cropped let
>>> me know
>>> >>> and I'll add an arg for that. The interface also needs a bit of
>>> work.
>>> >>> I was expecting the result to be symmetric, they are not.
>>> >>> v/r
>>> >>> NJK
>>> >>> _______________________________________________
>>> >>> OpenDroneMap-dev mailing list
>>> >>> OpenDroneMap-dev at lists.osgeo.org
>>> >>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-dev
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20150509/8072067b/attachment.html>
More information about the OpenDroneMap-dev
