[OpenDroneMap-dev] Image Correction
Cole colek42 at gmail.com
Sat May 9 08:52:12 PDT 2015
I just finished a major project at work as well as finals, I will definitly
have time to work on ODM over the next few weeks.
v/r
NJK
On Sat, May 9, 2015 at 8:44 AM, Stephen Mather <stephen at smathermather.com>
wrote:
> Alternatively, integrating a generalized version of Alex' work here:
> https://github.com/wildintellect/lenscorrection would be welcome.
> Cheers,
> Best,
> Steve
> On Sat, May 9, 2015 at 8:42 AM, Stephen Mather <stephen at smathermather.com>
> wrote:
>> Hi Cole,
>> Have you had time to do more with this? With Daryl, Alex, and others
>> proposing a python port, perhaps we could integrate it, and do distortion
>> correction at the front end of the processing chain for images that require
>> it by using this class + a user-built calibration library.
>> Thoughts?
>> Best,
>> Steve
>> On Thu, Mar 19, 2015 at 12:58 PM, Stephen Mather <
>> stephen at smathermather.com> wrote:
>>> It seems that the portion of the CMOS used, or effective chips size,
>>> would be different between video and stills, so calibration would be
>>> different for video and stills.
>>> On Thu, Mar 19, 2015 at 11:51 AM, Alex Mandel <
>>> tech_dev at wildintellect.com> wrote:
>>>> You don't want a video, you want still images. I can upload some later.
>>>> The problem with the video is that it's much lower resolution than time
>>>> lapse shots from the same camera and you end up grabbing frames from it
>>>> anyways.
>>>> Measuring the checkerboard loss from really close up shots is exactly
>>>> how I guessed the new sensor size.
>>>> Thanks,
>>>> Alex
>>>> On 03/19/2015 05:41 AM, Cole wrote:
>>>> > I was just going to email the list about that.  I would like to make
>>>> a test
>>>> > use case for this.  Since the ARDrone is probably not within our
>>>> normal use
>>>> > case, and I do not own a GoPro, would somebody be able to take a
>>>> video of a
>>>> > checkerboard pattern (
>>>> http://wiki.ros.org/camera_calibration/Tutorials/StereoCalibration?action=AttachFile&do=get&target=check-108.pdf
>>>> >  and share it.  Make sure you pan the camera so every part of the
>>>> sensor is
>>>> > covered by the pattern in at least one frame.  Orientation, skew, etc
>>>> does
>>>> > not matter.  Make sure you get it as some different distances as
>>>> well.  I
>>>> > think we can also calculate the CCD width of the cropped image based
>>>> on the
>>>> > width of the checkerboard cells.
>>>> > The next logical progression in this work would be to take video and
>>>> find
>>>> > the minimum number of overlapping frames to create a desirable result
>>>> > using RANSAC.  So if y'all have some aerial gopro video footage with
>>>> the
>>>> > exact same camera, I would appreciate that as well.
>>>> > As the I have a use case for my application with video inside and
>>>> outside
>>>> > of ROS, I will be posting a test case using the ARDrone, which uses a
>>>> > wide-angle camera.
>>>> > v/r
>>>> > NJK
>>>> > On Wed, Mar 18, 2015 at 11:33 PM, Stephen Mather <
>>>> > wrote:
>>>> >> Very interesting, I'll check it out. I'm thinking through the
>>>> implications
>>>> >> of no cropping, and while this won't affect matching, it likely will
>>>> cause
>>>> >> issues at the texturing stage, so a default cropping with optional
>>>> no-crop
>>>> >> would be useful. I assume a crop will affect the effective CCD
>>>> width, so
>>>> >> that will need calculated.
>>>> >> Is there any sharable wide-angle data for testing this?
>>>> >> Thanks,
>>>> >> Best,
>>>> >> Steve
>>>> >> On Tue, Mar 17, 2015 at 4:09 AM, Cole <colek42 at gmail.com> wrote:
>>>> >>> I have a image calibration class up at
>>>> https://github.com/colek42/TrackIt/blob/master/catkin/src/stabilize/src/calibrate.py
>>>> >>> It is working great.  I'll add a main function and comments in the
>>>> next
>>>> >>> day or so and do a pull request.  I am using an ARDrone camera, but
>>>> this is
>>>> >>> agnostic to the type of camera.  There is no cropping done, so the
>>>> edges
>>>> >>> are curved with a black background.  If it needs to be cropped let
>>>> me know
>>>> >>> and I'll add an arg for that.  The interface also needs a bit of
>>>> work.
>>>> >>> I was expecting the result to be symmetric, they are not.
>>>> >>> v/r
>>>> >>> NJK
>>>> >>> _______________________________________________
>>>> >>> OpenDroneMap-dev mailing list
>>>> >>> OpenDroneMap-dev at lists.osgeo.org
>>>> >>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-dev
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20150509/d87f8979/attachment-0001.html>
More information about the OpenDroneMap-dev mailing list
