[OpenDroneMap-users] question about resolution and camera orientation
Stephen Mather stephen at smathermather.com
Wed Feb 25 12:18:25 PST 2015
Also, once you like how the vagrantfile is configured, do a pull request
against odm_vagrant, as I think your laptop specs are pretty typical.
Thanks!
Best,
Steve
On Wed, Feb 25, 2015 at 3:17 PM, Stephen Mather <stephen at smathermather.com>
wrote:
> Ah yes, that vagrant file would explain why you aren't seeing threading!
> It is very conservative. Try something more like this (you'll need to
> modify the RAM and total number of processors):
> # -*- mode: ruby -*-
> # vi: set ft=ruby :
> # Vagrantfile API/syntax version. Don't touch unless you know what you're
> doing!
> VAGRANTFILE_API_VERSION = "2"
> Vagrant.configure(VAGRANTFILE_API_VERSION) do |config|
>   # Every Vagrant virtual environment requires a box to build from.
>   config.vm.box = "ubuntu/trusty64"
>   config.vm.synced_folder "../vodm_data", "/vagrant_data"
>   # Provider-specific configuration so you can fine-tune various
>   # backing providers for Vagrant. These expose provider-specific options.
>   # Example for VirtualBox:
>    config.vm.provider "virtualbox" do |vb|
>      vb.customize ["modifyvm", :id, "--memory", "20480"]
>  vb.cpus = 6
>      vb.customize ["modifyvm", :id, "--usb", "on"]
>    end
> end
> On Wed, Feb 25, 2015 at 11:33 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Wed, Feb 25, 2015 at 11:02 AM, Stephen Mather <
>> stephen at smathermather.com> wrote:
>>> Hi Anna,
>>> Matching should be parallelized. What are you running it on
>>> (hardware/hosting, OS)? Just Bundler should be single-threaded, if memory
>>> serves (not that memory always serves). My general recommendation is throw
>>> as much resources as possible. All the test datasets will process in a
>>> couple hours or less on a 32GB RAM digital ocean machine, which costs about
>>> $2 to run. I also have a workstation I do testing on which has 12
>>> processors and 32GB of RAM plus an SSD RAID. That is a pleasant machine to
>>> run datasets on. I know many have had success with larger Amazon instances
>>> as well -- perhaps someone on the list can speak to those experiences.
>>> As a point of contrast, running on a VM on my ultra-book is an exercise
>>> in frustration. :)
>> I am currently running it on my Ubuntu laptop (8 cores, 4GB memory), but
>> using the Vagrant file provided and it's really frustrating. I plan to move
>> it on a more powerful machine, but it was more convenient for me to test it
>> first on my machine.
>>> If it is a dataset you can share, I can run some tests and see if I am
>>> seeing similar issues.
>> I am not sure if the data can be shared. I will first try to run it on a
>> better machine and see if that helps.
>> Thanks for your help!
>> Anna
>>> Cheers,
>>> Best,
>>> Steve
>>> On Tue, Feb 24, 2015 at 10:58 PM, Anna Petrášová <kratochanna at gmail.com>
>>> wrote:
>>>> On Tue, Feb 24, 2015 at 10:23 PM, Stephen Mather <
>>>>> Hi Anna,
>>>>> Yes "--resize-to" will typically help get you a denser point cloud. I
>>>>> have found --resize-to 3000 to be a useful default, though the
>>>>> project currently defaults to 2400 to avoid swamping people's machines.
>>>> I am currently experimenting with larger images but it takes too long.
>>>> Just the matching takes forever. I wonder why the matching is not running
>>>> in parallel, if it's not implemented yet, it can't be implemented easily or
>>>> it gets confused since I am running it in virtual box?
>>>>> There's a lot to be done on the documentation side. Also, while the
>>>>> meshing and texturing portions of the codebase are novel, some other
>>>>> portions (Bundler, CMVS, PMVS) are projects onto themselves, so it will
>>>>> take a bit of exploration to figure out optimal parameters. As we (as a
>>>>> community) discover those optimal parameters, we can improve the sane
>>>>> defaults, and document good alternatives.
>>>> I was looking for some better documentation for these projects, but I
>>>> didn't find anything helpful. I wish I would know more about the actual
>>>> algorithms, but that's not my background.
>>>>> (That said, there is plenty of documentation to be written that I or
>>>>> others already know, so that is a priority)
>>>>> As to XYZ, yaw, pitch, and roll, OpenDroneMap does not yet take that
>>>>> into account. I would be excited to see this, perhaps even using SFCGAL or
>>>>> other 3D library for doing proper image footprints a la:
>>>>> https://smathermather.wordpress.com/2013/12/15/uas-drone-footprint-geometries-calculated-in-postgis-with-sfcgal-for-real-this-time/
>>>> Great blog!
>>>>> This would substantially reduce the processing time on the "match"
>>>>> step, which is a decent proportion of the current processing time.
>>>>> Also, I haven't written any documentation on it yet, but in the
>>>>> bundle.out file in reconstruction-with-image-size-2400 can be loaded
>>>>> in Meshlab to check camera positions and determine sanity of camera
>>>>> positions. There's a youtube video on that somewhere that I'll dig up.
>>>> Right, I noticed that.
>>>> Best,
>>>> Anna
>>>>> Cheers!
>>>>> Best,
>>>>> Steve
>>>>> On Tue, Feb 24, 2015 at 1:52 PM, Anna Petrášová <kratochanna at gmail.com
>>>>> > wrote:
>>>>>> On Tue, Feb 24, 2015 at 1:32 PM, Andy Wilde <awilde76 at gmail.com>
>>>>>> wrote:
>>>>>>> Hi Anna,
>>>>>>> For the resolution issues please read the wiki information which
>>>>>>> shows some of the parameter information.  This documentation is still under
>>>>>>> development and will improve.
>>>>>> Yes, I looked at the wiki, but I couldn't find what I was looking
>>>>>> for. I am still experimenting with different parameters so I will see. I
>>>>>> will definitely keep checking the wiki.
>>>>>>> For the X, Y, Z values the system will interpreted GPS information
>>>>>>> if it is in the image data,  I would expect that it will interpret x,y,y
>>>>>>> values in much the same way.  For the roll and yaw I do not think it will
>>>>>>> recognise this as yet.
>>>>>> Thanks,
>>>>>> Anna
>>>>>>> Sent from Mailbox <https://www.dropbox.com/mailbox>
>>>>>>> On Mon, Feb 23, 2015 at 9:28 PM, Anna Petrášová <
>>>>>>> kratochanna at gmail.com> wrote:
>>>>>>>> Hi,
>>>>>>>> I am trying to run opendronemap on my 200 images and a better
>>>>>>>> documentation of the different options would help me a lot. (I know,
>>>>>>>> writing documentation is always painful.) So I have a couple of questions.
>>>>>>>> 1. How do I increase the resolution? I need the point cloud from
>>>>>>>> which I would construct high-resolution raster DSM. Would higher
>>>>>>>> --resize-to do the job? Or a different parameter?
>>>>>>>> 2. I have the external orientation of camera (x, y, z, yaw, pitch,
>>>>>>>> roll), is there any way the algorithms could take advantage of this
>>>>>>>> information? I can imagine using these as initial values for the algorithm.
>>>>>>>> Thank you for this great software!
>>>>>>>> Anna
>>>>>> _______________________________________________
>>>>>> OpenDroneMap-users mailing list
>>>>>> OpenDroneMap-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150225/aa0d5d7e/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
