[OpenDroneMap-users] problem running ODM - parallel --halt-on-error 1 -j+0
Blake Girardot bgirardot at gmail.com
Wed Feb 25 16:46:57 PST 2015
Hi Ivan,
Are you sure ODM installed correctly?
Did you see the " - script finished " message at the end of the install
script?
You can just run the install script again, make sure it ends with script
finished.
Cheers,
Blake
On 2/26/2015 1:29 AM, Ivan Lizarazo wrote:
> Hi everybody,
> Many thanks to OpenDroneMap developers for such a great work.
> I've just installed ODM and  started to using it.
> However, I've got a problem when running|./run.pl  <http://run.pl>|  from the benchmark example data directory. I've got the following error:
> using existing DSC05531.JPG 	to /home/ivan/OpenDroneMap/odm_data/benchmark/reconstruction-with-image-size-2400/DSC05531.jpg	 (2400 x 1800)
>    - finding keypoints - mié feb 25 08:42:07 COT 2015
> sh: 1: /home/ivan/OpenDroneMap/bin/parallel: not found
> quitting cause:
> 	"/home/ivan/OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0 < "/home/ivan/OpenDroneMap/odm_data/benchmark/reconstruction-with-image-size-2400/_vlsift.templist.txt"
> returned with code 32512/
> My OS is Debian Wheezy running on an ASUS N56J laptop.
> Any suggestion for solving this issue will be appreciated.
> Best regards
> Ivan Lizarazo
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
