[OpenDroneMap-users] problem running ODM - parallel --halt-on-error 1 -j+0
Ivan Lizarazo
ivan.lizarazo at gmail.com
Thu Feb 26 01:26:04 PST 2015
Dear Blake,
As you noticed, my ODM installation was incomplete. I ran the install
script again and it ended with script finished.
I tried running ODM again. After a while I received this message:
Expanding patches...
---- EXPANSION: 14 secs ----
Total pass fail0 fail1 refinepatch: 8980 3660 1798 3522 7182
Total pass fail0 fail1 refinepatch: 100 40.7572 20.0223 39.2205 79.9777
FilterOutside
mainbody:
Gain (ave/var): 1.62477 0.76022
12422 -> 12410 (99.9034%) 0 secs
Filter Exact: **********
12410 -> 12059 (97.1716%) 0 secs
FilterNeighbor: 12059 -> 11582 (96.0444%) 0 secs
FilterGroups: 20
11582 -> 11363 (98.1091%) 0 secs
STATUS: 20773 0 19107 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0
---- Total: 0 secs ----
- running meshing -
- running texturing -
Error in OdmTexturing:
Failed to read image:
'/home/ivan/odm_data/benchmark//DSC05516.jpg'
For more detailed information, see log file.
quitting cause:
"/home/ivan/OpenDroneMap/bin/odm_texturing" -bundleFile
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
-imagesPath /home/ivan/odm_data/benchmark/ -imagesListPath
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txt
-inputModelPath
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
-outputFolder
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/
-textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
-logFile
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
returned with code 256
Any suggestion for solving this?
Best regards,
Ivan
On Wed, Feb 25, 2015 at 7:46 PM, Blake Girardot <bgirardot at gmail.com> wrote:
> Hi Ivan,
> Are you sure ODM installed correctly?
> Did you see the " - script finished " message at the end of the install
> script?
> You can just run the install script again, make sure it ends with script
> finished.
> Cheers,
> Blake
> On 2/26/2015 1:29 AM, Ivan Lizarazo wrote:
>> Hi everybody,
>> Many thanks to OpenDroneMap developers for such a great work.
>> I've just installed ODM and started to using it.
>> However, I've got a problem when running|./run.pl <http://run.pl>|
>> from the benchmark example data directory. I've got the following error:
>> using existing DSC05531.JPG to /home/ivan/OpenDroneMap/odm_
>> data/benchmark/reconstruction-with-image-size-2400/DSC05531.jpg (2400
>> x 1800)
>> - finding keypoints - mié feb 25 08:42:07 COT 2015
>> sh: 1: /home/ivan/OpenDroneMap/bin/parallel: not found
>> quitting cause:
>> "/home/ivan/OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0 <
>> "/home/ivan/OpenDroneMap/odm_data/benchmark/reconstruction-
>> with-image-size-2400/_vlsift.templist.txt"
>> returned with code 32512/
>> My OS is Debian Wheezy running on an ASUS N56J laptop.
>> Any suggestion for solving this issue will be appreciated.
>> Best regards
>> Ivan Lizarazo
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150226/c32ffffb/attachment-0001.html>
More information about the OpenDroneMap-users
