[OpenDroneMap-users] problem running ODM - parallel --halt-on-error 1 -j+0
Anna Petrášová kratochanna at gmail.com
Thu Feb 26 03:39:20 PST 2015
Hi Ivan,
On Thu, Feb 26, 2015 at 4:26 AM, Ivan Lizarazo <ivan.lizarazo at gmail.com>
wrote:
> Dear Blake,
> As you noticed, my ODM installation was incomplete. I ran the install
> script again and it ended with script finished.
> I tried running ODM again.  After a while I received this message:
I ran into this, too. You probably have images with upper case extension
JPG It's a known issue
https://github.com/OpenDroneMap/OpenDroneMap/issues/33
but it's easy to get around, just rename all your files to *.jpg.
Anna
> Expanding patches...
> ---- EXPANSION: 14 secs ----
> Total pass fail0 fail1 refinepatch: 8980 3660 1798 3522 7182
> Total pass fail0 fail1 refinepatch: 100 40.7572 20.0223 39.2205 79.9777
> FilterOutside
> mainbody:
> Gain (ave/var): 1.62477 0.76022
> 12422 -> 12410 (99.9034%)    0 secs
> Filter Exact: **********
> 12410 -> 12059 (97.1716%)    0 secs
> FilterNeighbor:    12059 -> 11582 (96.0444%)    0 secs
> FilterGroups:    20
> 11582 -> 11363 (98.1091%)    0 secs
> STATUS: 20773 0 19107 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0 0 0 0
> 0 0 0 0 0
> ---- Total: 0 secs ----
>   - running meshing -
>   - running texturing -
> Error in OdmTexturing:
> Failed to read image:
> '/home/ivan/odm_data/benchmark//DSC05516.jpg'
> For more detailed information, see log file.
> quitting cause:
>     "/home/ivan/OpenDroneMap/bin/odm_texturing" -bundleFile
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> -imagesPath /home/ivan/odm_data/benchmark/ -imagesListPath
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txt
> -inputModelPath
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
> -outputFolder
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/
> -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
> -logFile
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
> returned with code 256
> Any suggestion for solving this?
> Best regards,
> Ivan
> On Wed, Feb 25, 2015 at 7:46 PM, Blake Girardot <bgirardot at gmail.com>
> wrote:
>> Hi Ivan,
>> Are you sure ODM installed correctly?
>> Did you see the " - script finished " message at the end of the install
>> script?
>> You can just run the install script again, make sure it ends with script
>> finished.
>> Cheers,
>> Blake
>> On 2/26/2015 1:29 AM, Ivan Lizarazo wrote:
>>> Hi everybody,
>>> Many thanks to OpenDroneMap developers for such a great work.
>>> I've just installed ODM and  started to using it.
>>> However, I've got a problem when running|./run.pl  <http://run.pl>|
>>> from the benchmark example data directory. I've got the following error:
>>> using existing DSC05531.JPG     to /home/ivan/OpenDroneMap/odm_
>>> data/benchmark/reconstruction-with-image-size-2400/DSC05531.jpg   (2400
>>> x 1800)
>>>    - finding keypoints - mié feb 25 08:42:07 COT 2015
>>> sh: 1: /home/ivan/OpenDroneMap/bin/parallel: not found
>>> quitting cause:
>>>         "/home/ivan/OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0 <
>>> "/home/ivan/OpenDroneMap/odm_data/benchmark/reconstruction-
>>> with-image-size-2400/_vlsift.templist.txt"
>>> returned with code 32512/
>>> My OS is Debian Wheezy running on an ASUS N56J laptop.
>>> Any suggestion for solving this issue will be appreciated.
>>> Best regards
>>> Ivan Lizarazo
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150226/3072f3c5/attachment.html>
More information about the OpenDroneMap-users mailing list
