[OpenDroneMap-users] problem running ODM - parallel --halt-on-error 1 -j+0
Ivan Lizarazo ivan.lizarazo at gmail.com
Thu Feb 26 11:08:06 PST 2015
Dear Anna
Thank you for your suggestion.  I renamed all my images to *.jpg and could
complete the texturing step.
However, ODM could not execute the subsequent georeferencing step.  The
odm_georeferencing_log reads as follows:
*Arguments
given-bundleFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.out-gcpFile/home/ivan/odm_data/benchmark/gcp_list.txt-imagesPath/home/ivan/odm_data/benchmark/-imagesListPath/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txt-bundleResizedTo2400-inputFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj-outputFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj-logFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txtReading
cameras from:
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.outReading
GCPs from: /home/ivan/odm_data/benchmark/gcp_list.txtImages location is set
to: /home/ivan/odm_data/benchmark/Reading image list from:
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txtBundle
resize value is set to: 2400Reading textured mesh from:
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.objWriting
output to:
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.objLog
file path was set to:
/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txtError
in Georef:Failed opening /home/ivan/odm_data/benchmark/gcp_list.txt for
reading.*
It seems ODM needs a gcp_list.txt file to continue.  I understand that
georeferencing is the last step in the processing chain and that nothing
else remains to be done by ODM. Am I right?
Could anybody provide a gcp_list.txt for any of the odm_data examples?
Just to try to complete the data processing.
Best regards,
Ivan
On Thu, Feb 26, 2015 at 6:39 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> Hi Ivan,
> On Thu, Feb 26, 2015 at 4:26 AM, Ivan Lizarazo <ivan.lizarazo at gmail.com>
> wrote:
>> Dear Blake,
>> As you noticed, my ODM installation was incomplete. I ran the install
>> script again and it ended with script finished.
>> I tried running ODM again.  After a while I received this message:
> I ran into this, too. You probably have images with upper case extension
> JPG It's a known issue
> https://github.com/OpenDroneMap/OpenDroneMap/issues/33
> but it's easy to get around, just rename all your files to *.jpg.
> Anna
>> Expanding patches...
>> ---- EXPANSION: 14 secs ----
>> Total pass fail0 fail1 refinepatch: 8980 3660 1798 3522 7182
>> Total pass fail0 fail1 refinepatch: 100 40.7572 20.0223 39.2205 79.9777
>> FilterOutside
>> mainbody:
>> Gain (ave/var): 1.62477 0.76022
>> 12422 -> 12410 (99.9034%)    0 secs
>> Filter Exact: **********
>> 12410 -> 12059 (97.1716%)    0 secs
>> FilterNeighbor:    12059 -> 11582 (96.0444%)    0 secs
>> FilterGroups:    20
>> 11582 -> 11363 (98.1091%)    0 secs
>> STATUS: 20773 0 19107 0 0 0 0 0 0 0
>> 0 0 0 0 0 0 0 0 0 0
>> 0 0 0 0 0 0 0 0 0 0
>> 0 0 0 0 0
>> ---- Total: 0 secs ----
>>   - running meshing -
>>   - running texturing -
>> Error in OdmTexturing:
>> Failed to read image:
>> '/home/ivan/odm_data/benchmark//DSC05516.jpg'
>> For more detailed information, see log file.
>> quitting cause:
>>     "/home/ivan/OpenDroneMap/bin/odm_texturing" -bundleFile
>> -imagesPath /home/ivan/odm_data/benchmark/ -imagesListPath
>> -inputModelPath
>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
>> -outputFolder
>> -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
>> -logFile
>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
>> returned with code 256
>> Any suggestion for solving this?
>> Best regards,
>> Ivan
>> On Wed, Feb 25, 2015 at 7:46 PM, Blake Girardot <bgirardot at gmail.com>
>> wrote:
>>> Hi Ivan,
>>> Are you sure ODM installed correctly?
>>> Did you see the " - script finished " message at the end of the install
>>> script?
>>> You can just run the install script again, make sure it ends with script
>>> finished.
>>> Cheers,
>>> Blake
>>> On 2/26/2015 1:29 AM, Ivan Lizarazo wrote:
>>>> Hi everybody,
>>>> Many thanks to OpenDroneMap developers for such a great work.
>>>> I've just installed ODM and  started to using it.
>>>> However, I've got a problem when running|./run.pl  <http://run.pl>|
>>>> from the benchmark example data directory. I've got the following error:
>>>> using existing DSC05531.JPG     to /home/ivan/OpenDroneMap/odm_
>>>> data/benchmark/reconstruction-with-image-size-2400/DSC05531.jpg
>>>>  (2400 x 1800)
>>>>    - finding keypoints - mié feb 25 08:42:07 COT 2015
>>>> sh: 1: /home/ivan/OpenDroneMap/bin/parallel: not found
>>>> quitting cause:
>>>>         "/home/ivan/OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0
>>>> < "/home/ivan/OpenDroneMap/odm_data/benchmark/reconstruction-
>>>> with-image-size-2400/_vlsift.templist.txt"
>>>> returned with code 32512/
>>>> My OS is Debian Wheezy running on an ASUS N56J laptop.
>>>> Any suggestion for solving this issue will be appreciated.
>>>> Best regards
>>>> Ivan Lizarazo
>>>> _______________________________________________
>>>> OpenDroneMap-users mailing list
>>>> OpenDroneMap-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150226/44fec0aa/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
