[OpenDroneMap-users] problem running ODM - parallel --halt-on-error 1 -j+0
Stephen Mather stephen at smathermather.com
Sun Mar 1 14:31:25 PST 2015
Hi Ivan,
I finally added docs for this today. I am currently testing, so hopefully I
have documented correctly!
https://github.com/OpenDroneMap/OpenDroneMap/wiki/Running-OpenDroneMap
Also see:
https://smathermather.wordpress.com/2015/03/01/opendronemap-gcp-file-format/
Best,
Steve
On Thu, Feb 26, 2015 at 2:08 PM, Ivan Lizarazo <ivan.lizarazo at gmail.com>
wrote:
> Dear Anna
> Thank you for your suggestion.  I renamed all my images to *.jpg and could
> complete the texturing step.
> However, ODM could not execute the subsequent georeferencing step.  The
> odm_georeferencing_log reads as follows:
> *Arguments
> given-bundleFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.out-gcpFile/home/ivan/odm_data/benchmark/gcp_list.txt-imagesPath/home/ivan/odm_data/benchmark/-imagesListPath/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txt-bundleResizedTo2400-inputFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj-outputFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj-logFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txtReading
> cameras from:
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.outReading
> GCPs from: /home/ivan/odm_data/benchmark/gcp_list.txtImages location is set
> to: /home/ivan/odm_data/benchmark/Reading image list from:
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txtBundle
> resize value is set to: 2400Reading textured mesh from:
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.objWriting
> output to:
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.objLog
> file path was set to:
> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txtError
> in Georef:Failed opening /home/ivan/odm_data/benchmark/gcp_list.txt for
> reading.*
> It seems ODM needs a gcp_list.txt file to continue.  I understand that
> georeferencing is the last step in the processing chain and that nothing
> else remains to be done by ODM. Am I right?
> Could anybody provide a gcp_list.txt for any of the odm_data examples?
> Just to try to complete the data processing.
> Best regards,
> Ivan
> On Thu, Feb 26, 2015 at 6:39 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> Hi Ivan,
>> On Thu, Feb 26, 2015 at 4:26 AM, Ivan Lizarazo <ivan.lizarazo at gmail.com>
>> wrote:
>>> Dear Blake,
>>> As you noticed, my ODM installation was incomplete. I ran the install
>>> script again and it ended with script finished.
>>> I tried running ODM again.  After a while I received this message:
>> I ran into this, too. You probably have images with upper case extension
>> JPG It's a known issue
>> https://github.com/OpenDroneMap/OpenDroneMap/issues/33
>> but it's easy to get around, just rename all your files to *.jpg.
>> Anna
>>> Expanding patches...
>>> ---- EXPANSION: 14 secs ----
>>> Total pass fail0 fail1 refinepatch: 8980 3660 1798 3522 7182
>>> Total pass fail0 fail1 refinepatch: 100 40.7572 20.0223 39.2205 79.9777
>>> FilterOutside
>>> mainbody:
>>> Gain (ave/var): 1.62477 0.76022
>>> 12422 -> 12410 (99.9034%)    0 secs
>>> Filter Exact: **********
>>> 12410 -> 12059 (97.1716%)    0 secs
>>> FilterNeighbor:    12059 -> 11582 (96.0444%)    0 secs
>>> FilterGroups:    20
>>> 11582 -> 11363 (98.1091%)    0 secs
>>> STATUS: 20773 0 19107 0 0 0 0 0 0 0
>>> 0 0 0 0 0 0 0 0 0 0
>>> 0 0 0 0 0 0 0 0 0 0
>>> 0 0 0 0 0
>>> ---- Total: 0 secs ----
>>>   - running meshing -
>>>   - running texturing -
>>> Error in OdmTexturing:
>>> Failed to read image:
>>> '/home/ivan/odm_data/benchmark//DSC05516.jpg'
>>> For more detailed information, see log file.
>>> quitting cause:
>>>     "/home/ivan/OpenDroneMap/bin/odm_texturing" -bundleFile
>>> -imagesPath /home/ivan/odm_data/benchmark/ -imagesListPath
>>> -inputModelPath
>>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
>>> -outputFolder
>>> -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
>>> -logFile
>>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
>>> returned with code 256
>>> Any suggestion for solving this?
>>> Best regards,
>>> Ivan
>>> On Wed, Feb 25, 2015 at 7:46 PM, Blake Girardot <bgirardot at gmail.com>
>>> wrote:
>>>> Hi Ivan,
>>>> Are you sure ODM installed correctly?
>>>> Did you see the " - script finished " message at the end of the install
>>>> script?
>>>> You can just run the install script again, make sure it ends with
>>>> script finished.
>>>> Cheers,
>>>> Blake
>>>> On 2/26/2015 1:29 AM, Ivan Lizarazo wrote:
>>>>> Hi everybody,
>>>>> Many thanks to OpenDroneMap developers for such a great work.
>>>>> I've just installed ODM and  started to using it.
>>>>> However, I've got a problem when running|./run.pl  <http://run.pl>|
>>>>> from the benchmark example data directory. I've got the following error:
>>>>> using existing DSC05531.JPG     to /home/ivan/OpenDroneMap/odm_
>>>>> data/benchmark/reconstruction-with-image-size-2400/DSC05531.jpg
>>>>>  (2400 x 1800)
>>>>>    - finding keypoints - mié feb 25 08:42:07 COT 2015
>>>>> sh: 1: /home/ivan/OpenDroneMap/bin/parallel: not found
>>>>> quitting cause:
>>>>>         "/home/ivan/OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0
>>>>> < "/home/ivan/OpenDroneMap/odm_data/benchmark/reconstruction-
>>>>> with-image-size-2400/_vlsift.templist.txt"
>>>>> returned with code 32512/
>>>>> My OS is Debian Wheezy running on an ASUS N56J laptop.
>>>>> Any suggestion for solving this issue will be appreciated.
>>>>> Best regards
>>>>> Ivan Lizarazo
>>>>> _______________________________________________
>>>>> OpenDroneMap-users mailing list
>>>>> OpenDroneMap-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150301/05d438d1/attachment.html>
More information about the OpenDroneMap-users mailing list
