[OpenDroneMap-users] problem running ODM - parallel --halt-on-error 1 -j+0
Ivan Lizarazo
ivan.lizarazo at gmail.com
Mon Mar 2 17:19:09 PST 2015
Many thanks, Steve. I'll resume my ODM tests very soon.
Best regards,
Ivan
El domingo, 1 de marzo de 2015, Stephen Mather <stephen at smathermather.com>
escribió:
> Hi Ivan,
> I finally added docs for this today. I am currently testing, so hopefully
> I have documented correctly!
> https://github.com/OpenDroneMap/OpenDroneMap/wiki/Running-OpenDroneMap
> Also see:
> https://smathermather.wordpress.com/2015/03/01/opendronemap-gcp-file-format/
> Best,
> Steve
> On Thu, Feb 26, 2015 at 2:08 PM, Ivan Lizarazo <ivan.lizarazo at gmail.com
> <javascript:_e(%7B%7D,'cvml','ivan.lizarazo at gmail.com');>> wrote:
>> Dear Anna
>> Thank you for your suggestion. I renamed all my images to *.jpg and
>> could complete the texturing step.
>> However, ODM could not execute the subsequent georeferencing step. The
>> odm_georeferencing_log reads as follows:
>> *Arguments
>> given-bundleFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.out-gcpFile/home/ivan/odm_data/benchmark/gcp_list.txt-imagesPath/home/ivan/odm_data/benchmark/-imagesListPath/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txt-bundleResizedTo2400-inputFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj-outputFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj-logFile/home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txtReading
>> cameras from:
>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/bundle.rd.outReading
>> GCPs from: /home/ivan/odm_data/benchmark/gcp_list.txtImages location is set
>> to: /home/ivan/odm_data/benchmark/Reading image list from:
>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/pmvs/list.rd.txtBundle
>> resize value is set to: 2400Reading textured mesh from:
>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.objWriting
>> output to:
>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.objLog
>> file path was set to:
>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txtError
>> in Georef:Failed opening /home/ivan/odm_data/benchmark/gcp_list.txt for
>> reading.*
>> It seems ODM needs a gcp_list.txt file to continue. I understand that
>> georeferencing is the last step in the processing chain and that nothing
>> else remains to be done by ODM. Am I right?
>> Could anybody provide a gcp_list.txt for any of the odm_data examples?
>> Just to try to complete the data processing.
>> Best regards,
>> Ivan
>> On Thu, Feb 26, 2015 at 6:39 AM, Anna Petrášová <kratochanna at gmail.com
>> <javascript:_e(%7B%7D,'cvml','kratochanna at gmail.com');>> wrote:
>>> Hi Ivan,
>>> On Thu, Feb 26, 2015 at 4:26 AM, Ivan Lizarazo <ivan.lizarazo at gmail.com
>>>> Dear Blake,
>>>> As you noticed, my ODM installation was incomplete. I ran the install
>>>> script again and it ended with script finished.
>>>> I tried running ODM again. After a while I received this message:
>>> I ran into this, too. You probably have images with upper case extension
>>> JPG It's a known issue
>>> https://github.com/OpenDroneMap/OpenDroneMap/issues/33
>>> but it's easy to get around, just rename all your files to *.jpg.
>>> Anna
>>>> Expanding patches...
>>>> ---- EXPANSION: 14 secs ----
>>>> Total pass fail0 fail1 refinepatch: 8980 3660 1798 3522 7182
>>>> Total pass fail0 fail1 refinepatch: 100 40.7572 20.0223 39.2205 79.9777
>>>> FilterOutside
>>>> mainbody:
>>>> Gain (ave/var): 1.62477 0.76022
>>>> 12422 -> 12410 (99.9034%) 0 secs
>>>> Filter Exact: **********
>>>> 12410 -> 12059 (97.1716%) 0 secs
>>>> FilterNeighbor: 12059 -> 11582 (96.0444%) 0 secs
>>>> FilterGroups: 20
>>>> 11582 -> 11363 (98.1091%) 0 secs
>>>> STATUS: 20773 0 19107 0 0 0 0 0 0 0
>>>> 0 0 0 0 0 0 0 0 0 0
>>>> 0 0 0 0 0 0 0 0 0 0
>>>> 0 0 0 0 0
>>>> ---- Total: 0 secs ----
>>>> - running meshing -
>>>> - running texturing -
>>>> Error in OdmTexturing:
>>>> Failed to read image:
>>>> '/home/ivan/odm_data/benchmark//DSC05516.jpg'
>>>> For more detailed information, see log file.
>>>> quitting cause:
>>>> "/home/ivan/OpenDroneMap/bin/odm_texturing" -bundleFile
>>>> -imagesPath /home/ivan/odm_data/benchmark/ -imagesListPath
>>>> -inputModelPath
>>>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
>>>> -outputFolder
>>>> -textureResolution 4096 -bundleResizedTo 2400 -textureWithSize 3600
>>>> -logFile
>>>> /home/ivan/odm_data/benchmark/reconstruction-with-image-size-2400/odm_texturing/odm_texturing_log.txt
>>>> returned with code 256
>>>> Any suggestion for solving this?
>>>> Best regards,
>>>> Ivan
>>>> On Wed, Feb 25, 2015 at 7:46 PM, Blake Girardot <bgirardot at gmail.com
>>>> <javascript:_e(%7B%7D,'cvml','bgirardot at gmail.com');>> wrote:
>>>>> Hi Ivan,
>>>>> Are you sure ODM installed correctly?
>>>>> Did you see the " - script finished " message at the end of the
>>>>> install script?
>>>>> You can just run the install script again, make sure it ends with
>>>>> script finished.
>>>>> Cheers,
>>>>> Blake
>>>>> On 2/26/2015 1:29 AM, Ivan Lizarazo wrote:
>>>>>> Hi everybody,
>>>>>> Many thanks to OpenDroneMap developers for such a great work.
>>>>>> I've just installed ODM and started to using it.
>>>>>> However, I've got a problem when running|./run.pl <http://run.pl>|
>>>>>> from the benchmark example data directory. I've got the following error:
>>>>>> using existing DSC05531.JPG to /home/ivan/OpenDroneMap/odm_
>>>>>> data/benchmark/reconstruction-with-image-size-2400/DSC05531.jpg
>>>>>> (2400 x 1800)
>>>>>> - finding keypoints - mié feb 25 08:42:07 COT 2015
>>>>>> sh: 1: /home/ivan/OpenDroneMap/bin/parallel: not found
>>>>>> quitting cause:
>>>>>> "/home/ivan/OpenDroneMap/bin/parallel" --halt-on-error 1
>>>>>> -j+0 < "/home/ivan/OpenDroneMap/odm_data/benchmark/reconstruction-
>>>>>> with-image-size-2400/_vlsift.templist.txt"
>>>>>> returned with code 32512/
>>>>>> My OS is Debian Wheezy running on an ASUS N56J laptop.
>>>>>> Any suggestion for solving this issue will be appreciated.
>>>>>> Best regards
>>>>>> Ivan Lizarazo
>>>>>> _______________________________________________
>>>>>> OpenDroneMap-users mailing list
>>>>>> OpenDroneMap-users at lists.osgeo.org
>>>>>> <javascript:_e(%7B%7D,'cvml','OpenDroneMap-users at lists.osgeo.org');>
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150302/d19ea4f7/attachment.html>
More information about the OpenDroneMap-users
