[OpenDroneMap-users] Issues processing the copr data image set
Frederic Muller fred at cm17.com
Fri Mar 13 19:06:00 PDT 2015
Weird indeed. I'm redownloading the file and will try another time
today. Will keep you updated on the process.
Thank you.
Fred
On 03/14/2015 01:24 AM, Ivan Lizarazo wrote:
> Hi Fred
> Are you sure there is no a gcp_list.txt file in the odm_data_copr folder?
> I've just checked it at https://github.com/OpenDroneMap/odm_data_copr
> and found it. Please, review it.
> Ivan
> On Fri, Mar 13, 2015 at 1:03 PM, Frederic Muller <fred at cm17.com
> <mailto:fred at cm17.com>> wrote:
>     Hi!
>     Sorry for missing that out. Here is what it says:
>     Error in Georef:
>     Failed opening /home/fred/Documents/images/odm_data/copr/gcp_list.txt
>     for reading.
>     And checking into that folder the file doesn't seem to be there. Not
>     sure what else to add.
>     Fred
>     On 03/14/2015 12:46 AM, Ivan Lizarazo wrote:
>     > Hi Fred
>     > To get a clue, please review  the last few lines of  your
>     >  odm_georeferencing_log.txt and let us know what it says.
>     > Regards,
>     > Ivan
>     > On Fri, Mar 13, 2015 at 12:28 PM, Frederic Muller <fred at cm17.com <mailto:fred at cm17.com>
>     > <mailto:fred at cm17.com <mailto:fred at cm17.com>>> wrote:
>     >     Hi again,
>     >     So I renamed all the images and put them in small letters. And
>     now while
>     >     I went further away in the process I still have another issue:
>     >     quitting cause:
>      "/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef"
>     >     -bundleFile
>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
>     >     -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt
>     >     -imagesPath /home/fred/Documents/images/odm_data/copr/
>     >     -imagesListPath
>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt
>     >     -bundleResizedTo 2400 -inputFile
>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
>     >     -outputFile
>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
>     >     -logFile
>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
>     >     returned with code 256
>     >     Any idea what this could be?
>     >     Thank you.
>     >     Fred
>     >     On 03/12/2015 10:58 PM, Alex Mandel wrote:
>     >     > It's not the data set. Most of us have been hitting this bug
>     with the
>     >     > case of JPG not working and needing them to be jpg.
>     >     > https://github.com/OpenDroneMap/OpenDroneMap/issues/33
>     >     > I'll check that data set and update the names if they are
>     still in
>     >     caps
>     >     > in git.
>     >     > Thanks,
>     >     > Alex
>     >     > On 03/11/2015 12:11 AM, Frederic Muller wrote:
>     >     >> Hi!
>     >     >> Just installed ODM and trying to have it run first. I'm
>     using the
>     >     images
>     >     >> GitHub of the project and specifically ran on COPR images.
>     >     >> Unfortunately it has failed twice with the same error message
>     >     which is
>     >     >> "Error in OdmTexturing:
>     >     >> Failed to read image:
>     >     >> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
>     >     >> I looked at the image and it opens fine, but maybe the
>     problem comes
>     >     >> because of the double /?
>     >     >> Or is copr data set not ready?
>     >     >> Thank you.
>     >     >> Fred
>     >     _______________________________________________
>     >     OpenDroneMap-users mailing list
>     >     OpenDroneMap-users at lists.osgeo.org
>     <mailto:OpenDroneMap-users at lists.osgeo.org>
>     <mailto:OpenDroneMap-users at lists.osgeo.org>>
>     >     http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
