[OpenDroneMap-users] Issues processing the copr data image set
Frederic Muller
fred at cm17.com
Sat Mar 14 20:33:05 PDT 2015
Worked wonders, thank you for the help.
So now I have more questions related to the additional file that come
with the images: which ones are needed and how do you get them? (I
thought the GPS data were inside the image file, and then there is
slightly more in that gcp_list.txt
Thank you all.
Fred
On 03/14/2015 09:06 AM, Frederic Muller wrote:
> Weird indeed. I'm redownloading the file and will try another time
> today. Will keep you updated on the process.
> Thank you.
> Fred
> On 03/14/2015 01:24 AM, Ivan Lizarazo wrote:
>> Hi Fred
>> Are you sure there is no a gcp_list.txt file in the odm_data_copr folder?
>> I've just checked it at https://github.com/OpenDroneMap/odm_data_copr
>> and found it. Please, review it.
>> Ivan
>> On Fri, Mar 13, 2015 at 1:03 PM, Frederic Muller <fred at cm17.com
>> <mailto:fred at cm17.com>> wrote:
>> Hi!
>> Sorry for missing that out. Here is what it says:
>> Error in Georef:
>> Failed opening /home/fred/Documents/images/odm_data/copr/gcp_list.txt
>> for reading.
>> And checking into that folder the file doesn't seem to be there. Not
>> sure what else to add.
>> Fred
>> On 03/14/2015 12:46 AM, Ivan Lizarazo wrote:
>> > Hi Fred
>> > To get a clue, please review the last few lines of your
>> > odm_georeferencing_log.txt and let us know what it says.
>> > Regards,
>> > Ivan
>> > On Fri, Mar 13, 2015 at 12:28 PM, Frederic Muller <fred at cm17.com <mailto:fred at cm17.com>
>> > <mailto:fred at cm17.com <mailto:fred at cm17.com>>> wrote:
>> > Hi again,
>> > So I renamed all the images and put them in small letters. And
>> now while
>> > I went further away in the process I still have another issue:
>> > quitting cause:
>> "/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef"
>> > -bundleFile
>> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
>> > -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt
>> > -imagesPath /home/fred/Documents/images/odm_data/copr/
>> > -imagesListPath
>> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt
>> > -bundleResizedTo 2400 -inputFile
>> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
>> > -outputFile
>> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
>> > -logFile
>> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
>> > returned with code 256
>> > Any idea what this could be?
>> > Thank you.
>> > Fred
>> > On 03/12/2015 10:58 PM, Alex Mandel wrote:
>> > > It's not the data set. Most of us have been hitting this bug
>> with the
>> > > case of JPG not working and needing them to be jpg.
>> > > https://github.com/OpenDroneMap/OpenDroneMap/issues/33
>> > > I'll check that data set and update the names if they are
>> still in
>> > caps
>> > > in git.
>> > > Thanks,
>> > > Alex
>> > > On 03/11/2015 12:11 AM, Frederic Muller wrote:
>> > >> Hi!
>> > >> Just installed ODM and trying to have it run first. I'm
>> using the
>> > images
>> > >> GitHub of the project and specifically ran on COPR images.
>> > >> Unfortunately it has failed twice with the same error message
>> > which is
>> > >> "Error in OdmTexturing:
>> > >> Failed to read image:
>> > >> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
>> > >> I looked at the image and it opens fine, but maybe the
>> problem comes
>> > >> because of the double /?
>> > >> Or is copr data set not ready?
>> > >> Thank you.
>> > >> Fred
>> > _______________________________________________
>> > OpenDroneMap-users mailing list
>> > OpenDroneMap-users at lists.osgeo.org
>> <mailto:OpenDroneMap-users at lists.osgeo.org>
>> <mailto:OpenDroneMap-users at lists.osgeo.org>>
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users
