[OpenDroneMap-users] Issues processing the copr data image set
Alex Mandel tech_dev at wildintellect.com
Sat Mar 14 21:15:10 PDT 2015
There are 2 methods of georeferencing. GeoTags in the image exif data
that tells the location of the camera OR ground control points (gcp)
which is a known location in the image. You can use either.
FYI, even if the georeferencing step fails, the model is actually
completed before that and can be opened in meshlab. We are still testing
the orthophoto output on the COPR data set, as it's not coming out
usable for some reason. One of the other data sets is known to work.
Thanks,
Alex
PS: I only added the gcp file last week, that's probably why you didn't
have it.
On 03/14/2015 08:33 PM, Frederic Muller wrote:
> Worked wonders, thank you for the help.
> So now I have more questions related to the additional file that come
> with the images: which ones are needed and how do you get them? (I
> thought the GPS data were inside the image file, and then there is
> slightly more in that gcp_list.txt
> Thank you all.
> Fred
> On 03/14/2015 09:06 AM, Frederic Muller wrote:
>> Weird indeed. I'm redownloading the file and will try another time
>> today. Will keep you updated on the process.
>> Thank you.
>> Fred
>> On 03/14/2015 01:24 AM, Ivan Lizarazo wrote:
>>> Hi Fred
>>> Are you sure there is no a gcp_list.txt file in the odm_data_copr folder?
>>> I've just checked it at https://github.com/OpenDroneMap/odm_data_copr
>>> and found it. Please, review it.
>>> Ivan
>>> On Fri, Mar 13, 2015 at 1:03 PM, Frederic Muller <fred at cm17.com
>>> <mailto:fred at cm17.com>> wrote:
>>>     Hi!
>>>     Sorry for missing that out. Here is what it says:
>>>     Error in Georef:
>>>     Failed opening /home/fred/Documents/images/odm_data/copr/gcp_list.txt
>>>     for reading.
>>>     And checking into that folder the file doesn't seem to be there. Not
>>>     sure what else to add.
>>>     Fred
>>>     On 03/14/2015 12:46 AM, Ivan Lizarazo wrote:
>>>     > Hi Fred
>>>     > To get a clue, please review  the last few lines of  your
>>>     >  odm_georeferencing_log.txt and let us know what it says.
>>>     > Regards,
>>>     > Ivan
>>>     > On Fri, Mar 13, 2015 at 12:28 PM, Frederic Muller <fred at cm17.com <mailto:fred at cm17.com>
>>>     > <mailto:fred at cm17.com <mailto:fred at cm17.com>>> wrote:
>>>     >     Hi again,
>>>     >     So I renamed all the images and put them in small letters. And
>>>     now while
>>>     >     I went further away in the process I still have another issue:
>>>     >     quitting cause:
>>>      "/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef"
>>>     >     -bundleFile
>>>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
>>>     >     -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt
>>>     >     -imagesPath /home/fred/Documents/images/odm_data/copr/
>>>     >     -imagesListPath
>>>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt
>>>     >     -bundleResizedTo 2400 -inputFile
>>>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
>>>     >     -outputFile
>>>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
>>>     >     -logFile
>>>      /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
>>>     >     returned with code 256
>>>     >     Any idea what this could be?
>>>     >     Thank you.
>>>     >     Fred
>>>     >     On 03/12/2015 10:58 PM, Alex Mandel wrote:
>>>     >     > It's not the data set. Most of us have been hitting this bug
>>>     with the
>>>     >     > case of JPG not working and needing them to be jpg.
>>>     >     > https://github.com/OpenDroneMap/OpenDroneMap/issues/33
>>>     >     > I'll check that data set and update the names if they are
>>>     still in
>>>     >     caps
>>>     >     > in git.
>>>     >     > Thanks,
>>>     >     > Alex
>>>     >     > On 03/11/2015 12:11 AM, Frederic Muller wrote:
>>>     >     >> Hi!
>>>     >     >> Just installed ODM and trying to have it run first. I'm
>>>     using the
>>>     >     images
>>>     >     >> GitHub of the project and specifically ran on COPR images.
>>>     >     >> Unfortunately it has failed twice with the same error message
>>>     >     which is
>>>     >     >> "Error in OdmTexturing:
>>>     >     >> Failed to read image:
>>>     >     >> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
>>>     >     >> I looked at the image and it opens fine, but maybe the
>>>     problem comes
>>>     >     >> because of the double /?
>>>     >     >> Or is copr data set not ready?
>>>     >     >> Thank you.
>>>     >     >> Fred
>>>     >     _______________________________________________
>>>     >     OpenDroneMap-users mailing list
>>>     >     OpenDroneMap-users at lists.osgeo.org
>>>     <mailto:OpenDroneMap-users at lists.osgeo.org>
>>>     <mailto:OpenDroneMap-users at lists.osgeo.org>>
>>>     >     http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
