[OpenDroneMap-users] Issues processing the copr data image set
Frederic Muller
fred at cm17.com
Fri Mar 13 22:11:08 PDT 2015
Since we're on the topic, is there a way to resume the processing from
the point it failed? Or do we necessarily need to start from scratch?
Thank you.
Fred
On 03/14/2015 01:24 AM, Ivan Lizarazo wrote:
> Hi Fred
> Are you sure there is no a gcp_list.txt file in the odm_data_copr folder?
> I've just checked it at https://github.com/OpenDroneMap/odm_data_copr
> and found it. Please, review it.
> Ivan
> On Fri, Mar 13, 2015 at 1:03 PM, Frederic Muller <fred at cm17.com
> <mailto:fred at cm17.com>> wrote:
> Hi!
> Sorry for missing that out. Here is what it says:
> Error in Georef:
> Failed opening /home/fred/Documents/images/odm_data/copr/gcp_list.txt
> for reading.
> And checking into that folder the file doesn't seem to be there. Not
> sure what else to add.
> Fred
> On 03/14/2015 12:46 AM, Ivan Lizarazo wrote:
> > Hi Fred
> > To get a clue, please review the last few lines of your
> > odm_georeferencing_log.txt and let us know what it says.
> > Regards,
> > Ivan
> > On Fri, Mar 13, 2015 at 12:28 PM, Frederic Muller <fred at cm17.com <mailto:fred at cm17.com>
> > <mailto:fred at cm17.com <mailto:fred at cm17.com>>> wrote:
> > Hi again,
> > So I renamed all the images and put them in small letters. And
> now while
> > I went further away in the process I still have another issue:
> > quitting cause:
> "/home/fred/Documents/images/odm_data/copr/../../../odm/OpenDroneMap/bin/odm_georef"
> > -bundleFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/bundle.rd.out
> > -gcpFile /home/fred/Documents/images/odm_data/copr/gcp_list.txt
> > -imagesPath /home/fred/Documents/images/odm_data/copr/
> > -imagesListPath
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/pmvs/list.rd.txt
> > -bundleResizedTo 2400 -inputFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model.obj
> > -outputFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400-results/odm_texturing/odm_textured_model_geo.obj
> > -logFile
> /home/fred/Documents/images/odm_data/copr/reconstruction-with-image-size-2400/odm_georeferencing/odm_georeferencing_log.txt
> > returned with code 256
> > Any idea what this could be?
> > Thank you.
> > Fred
> > On 03/12/2015 10:58 PM, Alex Mandel wrote:
> > > It's not the data set. Most of us have been hitting this bug
> with the
> > > case of JPG not working and needing them to be jpg.
> > > https://github.com/OpenDroneMap/OpenDroneMap/issues/33
> > > I'll check that data set and update the names if they are
> still in
> > caps
> > > in git.
> > > Thanks,
> > > Alex
> > > On 03/11/2015 12:11 AM, Frederic Muller wrote:
> > >> Hi!
> > >> Just installed ODM and trying to have it run first. I'm
> using the
> > images
> > >> GitHub of the project and specifically ran on COPR images.
> > >> Unfortunately it has failed twice with the same error message
> > which is
> > >> "Error in OdmTexturing:
> > >> Failed to read image:
> > >> '/home/fred/Documents/odm_data/copr//IMG_0031.jpg'
> > >> I looked at the image and it opens fine, but maybe the
> problem comes
> > >> because of the double /?
> > >> Or is copr data set not ready?
> > >> Thank you.
> > >> Fred
> > OpenDroneMap-users mailing list
> > OpenDroneMap-users at lists.osgeo.org
> <mailto:OpenDroneMap-users at lists.osgeo.org>
> <mailto:OpenDroneMap-users at lists.osgeo.org>>
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users
