[OpenDroneMap-users] Install Issue
Todd Pals tpalshadow at gmail.com
Thu Mar 19 22:05:36 PDT 2015
Thanks for the help everyone.  I ended up creating a new machine using
12.04 instead of 14.04, took exactly the same setups steps for 12 as I did
for 14 and everything seems to be running now.  I'll give one of the test
image sets a try tomorrow.
On Thu, 19 Mar 2015 at 16:39 Todd Pals <tpalshadow at gmail.com> wrote:
> I created a brand new virtual machine and install of 14.04.  I made no
> changes to the machine and now it says installing and quits.  It did make
> progress as I now have an apt-get_install.log file, contents below:
> Reading package lists...
> Building dependency tree...
> Reading state information...
> gcc is already the newest version.
> perl is already the newest version.
> curl is already the newest version.
> curl set to manually installed.
> git is already the newest version.
> git set to manually installed.
> unzip is already the newest version.
> unzip set to manually installed.
> wget is already the newest version.
> wget set to manually installed.
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
>  libcheese-gtk23 : Depends: libclutter-gtk-1.0-0 (>= 0.91.8) but it is not
> going to be installed
>                    Depends: libcogl15 (>= 1.15.8) but it is not going to
> be installed
>  libcheese7 : Depends: libclutter-gst-2.0-0 (>= 0.10.0) but it is not
>               Depends: gstreamer1.0-clutter but it is not going to be
> installed
>  libclutter-1.0-0 : Depends: libcogl-pango15 (>= 1.15.8) but it is not
> be installed
> E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused
> by held packages.
> On Thu, 19 Mar 2015 at 13:31 Stephen Mather <stephen at smathermather.com>
> wrote:
>> Vagrant repo should work. It's a little light on ram, but otherwise
>> should be functional. The name of the repo is odm_vagrant in the
>> OpenDroneMap organization.
>> On Mar 19, 2015 1:50 PM, "Alex Mandel" <tech_dev at wildintellect.com>
>> wrote:
>>> That doesn't seem right, the stock Ubuntu would not include Chrome
>>> repos. We did have a Vagrant recipe but I'm not sure thats up to date.
>>> -Alex
>>> On 03/19/2015 10:32 AM, Todd Pals wrote:
>>> > Thanks for the hints, none of that made a difference...I  might wipe
>>> this
>>> > virtual machine and try again from scratch.  It was a fresh install of
>>> > Ubuntu downloaded and installed soley for trying to get opendronemap to
>>> > work, so I won't be losing out on anything.  I'm just using the .iso
>>> from
>>> > ubuntu.com, is there something else I should be using?
>>> > On Thu, 19 Mar 2015 at 12:02 Dennis Baldwin <db at unmannedairlines.com>
>>> wrote:
>>> >> Try this:
>>> >> https://coderwall.com/p/3n6xka/fix-apt-on-old-
>>> unsupported-ubuntu-releases
>>> >> and if that doesn't work I'm attaching my sources.list that maybe you
>>> can
>>> >> try.
>>> >> Good luck and keep us posted.
>>> >> On Thu, Mar 19, 2015 at 11:51 AM, Todd Pals <tpalshadow at gmail.com>
>>> wrote:
>>> >>> I do get an error:
>>> >>> Fetched 2,606 kB in 18s (138 kB/s)
>>> >>> W: Failed to fetch
>>> >>> http://dl.google.com/linux/chrome/deb/dists/stable/main/
>>> binary-amd64/Packages
>>> >>>  403  Forbidden [IP: 74.125.196.136 80]
>>> >>> W: Failed to fetch
>>> binary-i386/Packages
>>> >>> E: Some index files failed to download. They have been ignored, or
>>> old
>>> >>> ones used instead.
>>> >>> Here are the contents of sources.list:
>>> >>> #deb cdrom:[Ubuntu 14.04.2 LTS _Trusty Tahr_ - Release amd64
>>> >>> (20150218.1)]/ trus
>>> >>> ty main restricted
>>> >>> # See http://help.ubuntu.com/community/UpgradeNotes for how to
>>> upgrade to
>>> >>> # newer versions of the distribution.
>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>>> >>> ## Major bug fix updates produced after the final release of the
>>> >>> ## distribution.
>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>> restricted
>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>> >>> restricted
>>> >>> ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the
>>> >>> Ubuntu
>>> >>> ## team. Also, please note that software in universe WILL NOT
>>> receive any
>>> >>> ## review or updates from the Ubuntu security team.
>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
>>> >>> Ubuntu
>>> >>> ## team, and may not be under a free licence. Please satisfy
>>> yourself as
>>> >>> to
>>> >>> ## your rights to use the software. Also, please note that software
>>> in
>>> >>> ## multiverse WILL NOT receive any review or updates from the Ubuntu
>>> >>> ## security team.
>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
>>> multiverse
>>> >>> ## N.B. software from this repository may not have been tested as
>>> >>> ## extensively as that contained in the main release, although it
>>> includes
>>> >>> ## newer versions of some applications which may provide useful
>>> features.
>>> >>> ## Also, please note that software in backports WILL NOT receive any
>>> >>> review
>>> >>> ## or updates from the Ubuntu security team.
>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>>> >>> restricted univer
>>> >>> se multiverse
>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>>> >>> restricted un
>>> >>> iverse multiverse
>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security main
>>> restricted
>>> >>> deb-src http://security.ubuntu.com/ubuntu trusty-security main
>>> restricted
>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security universe
>>> >>> deb-src http://security.ubuntu.com/ubuntu trusty-security universe
>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security multiverse
>>> >>> deb-src http://security.ubuntu.com/ubuntu trusty-security multiverse
>>> >>> ## Uncomment the following two lines to add software from Canonical's
>>> >>> ## 'partner' repository.
>>> >>> ## This software is not part of Ubuntu, but is offered by Canonical
>>> and
>>> >>> the
>>> >>> ## respective vendors as a service to Ubuntu users.
>>> >>> # deb http://archive.canonical.com/ubuntu trusty partner
>>> >>> # deb-src http://archive.canonical.com/ubuntu trusty partner
>>> >>> ## This software is not part of Ubuntu, but is offered by third-party
>>> >>> ## developers who want to ship their latest software.
>>> >>> deb http://extras.ubuntu.com/ubuntu trusty main
>>> >>> deb-src http://extras.ubuntu.com/ubuntu trusty main
>>> >>> todd at todd-VirtualBox:/etc/apt$
>>> >>> Thanks!
>>> >>> On Thu, 19 Mar 2015 at 11:46 Dennis Baldwin <db at unmannedairlines.com
>>> >>> wrote:
>>> >>>> Strange. I just did an install on 14.04 with no problems. I wonder
>>> if
>>> >>>> it's an issue with your sources.list. It looks like it's failing
>>> here:
>>> >>>> https://github.com/OpenDroneMap/OpenDroneMap/
>>> blob/gh-pages/install.sh#L107
>>> >>>> Try running this directly from your command line and see if you
>>> still
>>> >>>> get that 403 error:
>>> >>>> sudo apt-get update --assume-yes
>>> >>>> If so, paste your /etc/apt/sources.list and I'll compare with mine.
>>> >>>> On Thu, Mar 19, 2015 at 11:31 AM, Todd Pals <tpalshadow at gmail.com>
>>> >>>> wrote:
>>> >>>>> apt-get_get.log and sysinfo.txt are the only two files in the logs
>>> >>>>> directory.
>>> >>>>> On Thu, 19 Mar 2015 at 11:27 Dennis Baldwin <
>>> >>>>> wrote:
>>> >>>>>> Hey Todd,
>>> >>>>>> What about attaching apt-get_install.log? I see those 403 in the
>>> >>>>>> apt-get_get.log but not sure those are really the problem. The
>>> >>>>>> apt-get_install should hopefully give us more info.
>>> >>>>>> Dennis
>>> >>>>>> On Thu, Mar 19, 2015 at 8:42 AM, Todd Pals <tpalshadow at gmail.com>
>>> >>>>>> wrote:
>>> >>>>>>> Here are the logs, thanks!
>>> >>>>>>> On Wed, 18 Mar 2015 at 21:56 Alex Mandel <
>>> >>>>>>> wrote:
>>> >>>>>>>> Yup check the log, if you're install stopped at the Updating
>>> step
>>> >>>>>>>> then
>>> >>>>>>>> there was a failure really early on installing packages via
>>> apt-get.
>>> >>>>>>>> FYI, the install.sh is really readable.
>>> >>>>>>>> -Alex
>>> >>>>>>>> On 03/18/2015 07:16 PM, Blake Girardot wrote:
>>> >>>>>>>>> Hi,
>>> >>>>>>>>> There should be a logs folder in the install directory. Can you
>>> >>>>>>>> open
>>> >>>>>>>>> file with the latest last modification time and put the
>>> contents
>>> >>>>>>>> of that
>>> >>>>>>>>> log in an email?
>>> >>>>>>>>> Cheers,
>>> >>>>>>>>> Blake
>>> >>>>>>>>> On 3/19/2015 3:06 AM, Todd Pals wrote:
>>> >>>>>>>>>> First let me apologize for incorrectly posting to the github
>>> >>>>>>>> earlier
>>> >>>>>>>>>> today, I'm sorry about that.
>>> >>>>>>>>>> I am new to the Linux, so if I'm completely dumb in what I'm
>>> >>>>>>>> asking,
>>> >>>>>>>>>> just let me know. You won't hurt my feelings. I'm running
>>> Ubuntu
>>> >>>>>>>> 14.04
>>> >>>>>>>>>> LTS on an Oracle VirtualBox (setup just for this).
>>> >>>>>>>>>> When I run the install I get this:
>>> >>>>>>>>>> todd at todd-VirtualBox:~/Documents/OpenDroneMap$ sudo
>>> ./install.sh
>>> >>>>>>>>>>   created by Daniel Schwarz/daniel.schwarz at topoi.org
>>> >>>>>>>>>> <mailto:daniel.schwarz at topoi.org>
>>> >>>>>>>>>>   released under Creative Commons/CC-BY
>>> >>>>>>>>>>   Attribution
>>> >>>>>>>>>>   if the script doesn't finish properly
>>> >>>>>>>>>>   (i.e. it doesn't print "script finished" at the end)
>>> >>>>>>>>>>   please email me the content of the logs folder
>>> >>>>>>>>>> script started - Wed Mar 18 16:18:44 CDT 2015
>>> >>>>>>>>>> installing required packages
>>> >>>>>>>>>> - updating
>>> >>>>>>>>>> And nothing seems to happen. If I try and run a set of the
>>> sample
>>> >>>>>>>> images
>>> >>>>>>>>>> or the set that Dennis Baldwin has in his videos I get this:
>>> >>>>>>>>>> sh: 1: jhead: not found
>>> >>>>>>>>>> no CCD width or focal length found for img_4851.jpg - camera:
>>> >>>>>>>> "sh: 1:
>>> >>>>>>>>>> jhead: not found
>>> >>>>>>>>>> Any help would be appreciated!
>>> >>>>>>>>>> -Todd
>>> >>>>>>>>>> _______________________________________________
>>> >>>>>>>>>> OpenDroneMap-users mailing list
>>> >>>>>>>>>> OpenDroneMap-users at lists.osgeo.org
>>> >>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/
>>> >>>>>>>> opendronemap-users
>>> opendronemap-users
>>> opendronemap-users
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150320/551e73cc/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
