[OpenDroneMap-users] Install Issue
Todd Pals
tpalshadow at gmail.com
Fri Mar 20 10:22:02 PDT 2015
More problems, maybe I'm not cut out for this at this point.
I am trying to install it here at work and it errors out with: mv: cannot
stat `parallel-20141022': No such file or directory
The extract_parallel.tar.bz2.log file says:
bzip2: (stdin) is not a bzip2 file.
tar: Child returned status 2
tar: Error is not recoverable: exiting now
On Fri, 20 Mar 2015 at 00:05 Todd Pals <tpalshadow at gmail.com> wrote:
> Thanks for the help everyone. I ended up creating a new machine using
> 12.04 instead of 14.04, took exactly the same setups steps for 12 as I did
> for 14 and everything seems to be running now. I'll give one of the test
> image sets a try tomorrow.
> On Thu, 19 Mar 2015 at 16:39 Todd Pals <tpalshadow at gmail.com> wrote:
>> I created a brand new virtual machine and install of 14.04. I made no
>> changes to the machine and now it says installing and quits. It did make
>> progress as I now have an apt-get_install.log file, contents below:
>> Reading package lists...
>> Building dependency tree...
>> Reading state information...
>> gcc is already the newest version.
>> perl is already the newest version.
>> curl is already the newest version.
>> curl set to manually installed.
>> git is already the newest version.
>> git set to manually installed.
>> unzip is already the newest version.
>> unzip set to manually installed.
>> wget is already the newest version.
>> wget set to manually installed.
>> Some packages could not be installed. This may mean that you have
>> requested an impossible situation or if you are using the unstable
>> distribution that some required packages have not yet been created
>> or been moved out of Incoming.
>> The following information may help to resolve the situation:
>> The following packages have unmet dependencies:
>> libcheese-gtk23 : Depends: libclutter-gtk-1.0-0 (>= 0.91.8) but it is
>> not going to be installed
>> Depends: libcogl15 (>= 1.15.8) but it is not going to
>> be installed
>> libcheese7 : Depends: libclutter-gst-2.0-0 (>= 0.10.0) but it is not
>> Depends: gstreamer1.0-clutter but it is not going to be
>> installed
>> libclutter-1.0-0 : Depends: libcogl-pango15 (>= 1.15.8) but it is not
>> be installed
>> E: Error, pkgProblemResolver::Resolve generated breaks, this may be
>> caused by held packages.
>> On Thu, 19 Mar 2015 at 13:31 Stephen Mather <stephen at smathermather.com>
>> wrote:
>>> Vagrant repo should work. It's a little light on ram, but otherwise
>>> should be functional. The name of the repo is odm_vagrant in the
>>> OpenDroneMap organization.
>>> On Mar 19, 2015 1:50 PM, "Alex Mandel" <tech_dev at wildintellect.com>
>>> wrote:
>>>> That doesn't seem right, the stock Ubuntu would not include Chrome
>>>> repos. We did have a Vagrant recipe but I'm not sure thats up to date.
>>>> -Alex
>>>> On 03/19/2015 10:32 AM, Todd Pals wrote:
>>>> > Thanks for the hints, none of that made a difference...I might wipe
>>>> this
>>>> > virtual machine and try again from scratch. It was a fresh install of
>>>> > Ubuntu downloaded and installed soley for trying to get opendronemap
>>>> to
>>>> > work, so I won't be losing out on anything. I'm just using the .iso
>>>> from
>>>> > ubuntu.com, is there something else I should be using?
>>>> > On Thu, 19 Mar 2015 at 12:02 Dennis Baldwin <db at unmannedairlines.com>
>>>> wrote:
>>>> >> Try this:
>>>> >> https://coderwall.com/p/3n6xka/fix-apt-on-old-unsupported-
>>>> ubuntu-releases
>>>> >> and if that doesn't work I'm attaching my sources.list that maybe
>>>> you can
>>>> >> try.
>>>> >> Good luck and keep us posted.
>>>> >> On Thu, Mar 19, 2015 at 11:51 AM, Todd Pals <tpalshadow at gmail.com>
>>>> wrote:
>>>> >>> I do get an error:
>>>> >>> Fetched 2,606 kB in 18s (138 kB/s)
>>>> >>> W: Failed to fetch
>>>> >>> http://dl.google.com/linux/chrome/deb/dists/stable/main/bina
>>>> ry-amd64/Packages
>>>> >>> 403 Forbidden [IP: 74.125.196.136 80]
>>>> >>> W: Failed to fetch
>>>> ry-i386/Packages
>>>> >>> E: Some index files failed to download. They have been ignored, or
>>>> old
>>>> >>> ones used instead.
>>>> >>> Here are the contents of sources.list:
>>>> >>> #deb cdrom:[Ubuntu 14.04.2 LTS _Trusty Tahr_ - Release amd64
>>>> >>> (20150218.1)]/ trus
>>>> >>> ty main restricted
>>>> >>> # See http://help.ubuntu.com/community/UpgradeNotes for how to
>>>> upgrade to
>>>> >>> # newer versions of the distribution.
>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>>>> >>> ## Major bug fix updates produced after the final release of the
>>>> >>> ## distribution.
>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>>> restricted
>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>>> >>> restricted
>>>> >>> ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the
>>>> >>> Ubuntu
>>>> >>> ## team. Also, please note that software in universe WILL NOT
>>>> receive any
>>>> >>> ## review or updates from the Ubuntu security team.
>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
>>>> universe
>>>> >>> Ubuntu
>>>> >>> ## team, and may not be under a free licence. Please satisfy
>>>> yourself as
>>>> >>> to
>>>> >>> ## your rights to use the software. Also, please note that software
>>>> in
>>>> >>> ## multiverse WILL NOT receive any review or updates from the Ubuntu
>>>> >>> ## security team.
>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
>>>> multiverse
>>>> >>> ## N.B. software from this repository may not have been tested as
>>>> >>> ## extensively as that contained in the main release, although it
>>>> includes
>>>> >>> ## newer versions of some applications which may provide useful
>>>> features.
>>>> >>> ## Also, please note that software in backports WILL NOT receive any
>>>> >>> review
>>>> >>> ## or updates from the Ubuntu security team.
>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>>>> >>> restricted univer
>>>> >>> se multiverse
>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>>>> >>> restricted un
>>>> >>> iverse multiverse
>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security main
>>>> restricted
>>>> >>> deb-src http://security.ubuntu.com/ubuntu trusty-security main
>>>> restricted
>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security universe
>>>> >>> deb-src http://security.ubuntu.com/ubuntu trusty-security universe
>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security multiverse
>>>> multiverse
>>>> >>> ## Uncomment the following two lines to add software from
>>>> Canonical's
>>>> >>> ## 'partner' repository.
>>>> >>> ## This software is not part of Ubuntu, but is offered by Canonical
>>>> and
>>>> >>> the
>>>> >>> ## respective vendors as a service to Ubuntu users.
>>>> >>> # deb http://archive.canonical.com/ubuntu trusty partner
>>>> >>> # deb-src http://archive.canonical.com/ubuntu trusty partner
>>>> third-party
>>>> >>> ## developers who want to ship their latest software.
>>>> >>> deb http://extras.ubuntu.com/ubuntu trusty main
>>>> >>> deb-src http://extras.ubuntu.com/ubuntu trusty main
>>>> >>> todd at todd-VirtualBox:/etc/apt$
>>>> >>> Thanks!
>>>> >>> On Thu, 19 Mar 2015 at 11:46 Dennis Baldwin <
>>>> >>> wrote:
>>>> >>>> Strange. I just did an install on 14.04 with no problems. I wonder
>>>> if
>>>> >>>> it's an issue with your sources.list. It looks like it's failing
>>>> here:
>>>> >>>> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/
>>>> install.sh#L107
>>>> >>>> Try running this directly from your command line and see if you
>>>> still
>>>> >>>> get that 403 error:
>>>> >>>> sudo apt-get update --assume-yes
>>>> >>>> If so, paste your /etc/apt/sources.list and I'll compare with mine.
>>>> >>>> On Thu, Mar 19, 2015 at 11:31 AM, Todd Pals <tpalshadow at gmail.com>
>>>> >>>> wrote:
>>>> >>>>> apt-get_get.log and sysinfo.txt are the only two files in the logs
>>>> >>>>> directory.
>>>> >>>>> On Thu, 19 Mar 2015 at 11:27 Dennis Baldwin <
>>>> >>>>> wrote:
>>>> >>>>>> Hey Todd,
>>>> >>>>>> What about attaching apt-get_install.log? I see those 403 in the
>>>> >>>>>> apt-get_get.log but not sure those are really the problem. The
>>>> >>>>>> apt-get_install should hopefully give us more info.
>>>> >>>>>> Dennis
>>>> >>>>>> On Thu, Mar 19, 2015 at 8:42 AM, Todd Pals <tpalshadow at gmail.com
>>>> >>>>>> wrote:
>>>> >>>>>>> Here are the logs, thanks!
>>>> >>>>>>> On Wed, 18 Mar 2015 at 21:56 Alex Mandel <
>>>> >>>>>>> wrote:
>>>> >>>>>>>> Yup check the log, if you're install stopped at the Updating
>>>> step
>>>> >>>>>>>> then
>>>> >>>>>>>> there was a failure really early on installing packages via
>>>> apt-get.
>>>> >>>>>>>> FYI, the install.sh is really readable.
>>>> >>>>>>>> -Alex
>>>> >>>>>>>> On 03/18/2015 07:16 PM, Blake Girardot wrote:
>>>> >>>>>>>>> Hi,
>>>> >>>>>>>>> There should be a logs folder in the install directory. Can
>>>> you
>>>> >>>>>>>> open
>>>> >>>>>>>>> file with the latest last modification time and put the
>>>> contents
>>>> >>>>>>>> of that
>>>> >>>>>>>>> log in an email?
>>>> >>>>>>>>> Cheers,
>>>> >>>>>>>>> Blake
>>>> >>>>>>>>> On 3/19/2015 3:06 AM, Todd Pals wrote:
>>>> >>>>>>>>>> First let me apologize for incorrectly posting to the github
>>>> >>>>>>>> earlier
>>>> >>>>>>>>>> today, I'm sorry about that.
>>>> >>>>>>>>>> I am new to the Linux, so if I'm completely dumb in what I'm
>>>> >>>>>>>> asking,
>>>> >>>>>>>>>> just let me know. You won't hurt my feelings. I'm running
>>>> Ubuntu
>>>> >>>>>>>> 14.04
>>>> >>>>>>>>>> LTS on an Oracle VirtualBox (setup just for this).
>>>> >>>>>>>>>> When I run the install I get this:
>>>> >>>>>>>>>> todd at todd-VirtualBox:~/Documents/OpenDroneMap$ sudo
>>>> ./install.sh
>>>> >>>>>>>>>> created by Daniel Schwarz/daniel.schwarz at topoi.org
>>>> >>>>>>>>>> <mailto:daniel.schwarz at topoi.org>
>>>> >>>>>>>>>> released under Creative Commons/CC-BY
>>>> >>>>>>>>>> Attribution
>>>> >>>>>>>>>> if the script doesn't finish properly
>>>> >>>>>>>>>> (i.e. it doesn't print "script finished" at the end)
>>>> >>>>>>>>>> please email me the content of the logs folder
>>>> >>>>>>>>>> script started - Wed Mar 18 16:18:44 CDT 2015
>>>> >>>>>>>>>> installing required packages
>>>> >>>>>>>>>> - updating
>>>> >>>>>>>>>> And nothing seems to happen. If I try and run a set of the
>>>> sample
>>>> >>>>>>>> images
>>>> >>>>>>>>>> or the set that Dennis Baldwin has in his videos I get this:
>>>> >>>>>>>>>> sh: 1: jhead: not found
>>>> >>>>>>>>>> no CCD width or focal length found for img_4851.jpg -
>>>> camera: "
>>>> >>>>>>>> "sh: 1:
>>>> >>>>>>>>>> jhead: not found
>>>> >>>>>>>>>> Any help would be appreciated!
>>>> >>>>>>>>>> -Todd
>>>> >>>>>>>>>> _______________________________________________
>>>> >>>>>>>>>> OpenDroneMap-users mailing list
>>>> >>>>>>>>>> OpenDroneMap-users at lists.osgeo.org
>>>> >>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/
>>>> >>>>>>>> opendronemap-users
>>>> >>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap
>>>> -users
>>>> -users
>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150320/4642d414/attachment-0001.html>
More information about the OpenDroneMap-users
