[OpenDroneMap-users] Install Issue
Todd Pals tpalshadow at gmail.com
Fri Mar 20 10:48:27 PDT 2015
Is the http://ftp.gnu.org/gnu/parallel/parallel-20141022.tar.bz2 file
supposed to be 2.6 kb or larger?
On Fri, 20 Mar 2015 at 12:36 Dennis Baldwin <db at unmannedairlines.com> wrote:
> I ran into this early on. Maybe this will help:
> https://github.com/OpenDroneMap/OpenDroneMap/issues/7
> Keep us posted.
> On Fri, Mar 20, 2015 at 12:22 PM, Todd Pals <tpalshadow at gmail.com> wrote:
>> More problems, maybe I'm not cut out for this at this point.
>> I am trying to install it here at work and it errors out with: mv: cannot
>> stat `parallel-20141022': No such file or directory
>> The extract_parallel.tar.bz2.log file says:
>> bzip2: (stdin) is not a bzip2 file.
>> tar: Child returned status 2
>> tar: Error is not recoverable: exiting now
>> On Fri, 20 Mar 2015 at 00:05 Todd Pals <tpalshadow at gmail.com> wrote:
>>> Thanks for the help everyone.  I ended up creating a new machine using
>>> 12.04 instead of 14.04, took exactly the same setups steps for 12 as I did
>>> for 14 and everything seems to be running now.  I'll give one of the test
>>> image sets a try tomorrow.
>>> On Thu, 19 Mar 2015 at 16:39 Todd Pals <tpalshadow at gmail.com> wrote:
>>>> I created a brand new virtual machine and install of 14.04.  I made no
>>>> changes to the machine and now it says installing and quits.  It did make
>>>> progress as I now have an apt-get_install.log file, contents below:
>>>> Reading package lists...
>>>> Building dependency tree...
>>>> Reading state information...
>>>> gcc is already the newest version.
>>>> perl is already the newest version.
>>>> curl is already the newest version.
>>>> curl set to manually installed.
>>>> git is already the newest version.
>>>> git set to manually installed.
>>>> unzip is already the newest version.
>>>> unzip set to manually installed.
>>>> wget is already the newest version.
>>>> wget set to manually installed.
>>>> Some packages could not be installed. This may mean that you have
>>>> requested an impossible situation or if you are using the unstable
>>>> distribution that some required packages have not yet been created
>>>> or been moved out of Incoming.
>>>> The following information may help to resolve the situation:
>>>> The following packages have unmet dependencies:
>>>>  libcheese-gtk23 : Depends: libclutter-gtk-1.0-0 (>= 0.91.8) but it is
>>>> not going to be installed
>>>>                    Depends: libcogl15 (>= 1.15.8) but it is not going
>>>> to be installed
>>>>  libcheese7 : Depends: libclutter-gst-2.0-0 (>= 0.10.0) but it is not
>>>>               Depends: gstreamer1.0-clutter but it is not going to be
>>>> installed
>>>>  libclutter-1.0-0 : Depends: libcogl-pango15 (>= 1.15.8) but it is not
>>>> to be installed
>>>> E: Error, pkgProblemResolver::Resolve generated breaks, this may be
>>>> caused by held packages.
>>>> On Thu, 19 Mar 2015 at 13:31 Stephen Mather <stephen at smathermather.com>
>>>> wrote:
>>>>> Vagrant repo should work. It's a little light on ram, but otherwise
>>>>> should be functional. The name of the repo is odm_vagrant in the
>>>>> OpenDroneMap organization.
>>>>> On Mar 19, 2015 1:50 PM, "Alex Mandel" <tech_dev at wildintellect.com>
>>>>> wrote:
>>>>>> That doesn't seem right, the stock Ubuntu would not include Chrome
>>>>>> repos. We did have a Vagrant recipe but I'm not sure thats up to date.
>>>>>> -Alex
>>>>>> On 03/19/2015 10:32 AM, Todd Pals wrote:
>>>>>> > Thanks for the hints, none of that made a difference...I  might
>>>>>> wipe this
>>>>>> > virtual machine and try again from scratch.  It was a fresh install
>>>>>> of
>>>>>> > Ubuntu downloaded and installed soley for trying to get
>>>>>> opendronemap to
>>>>>> > work, so I won't be losing out on anything.  I'm just using the
>>>>>> .iso from
>>>>>> > ubuntu.com, is there something else I should be using?
>>>>>> > On Thu, 19 Mar 2015 at 12:02 Dennis Baldwin <
>>>>>> >> Try this:
>>>>>> >> https://coderwall.com/p/3n6xka/fix-apt-on-old-unsupported-
>>>>>> ubuntu-releases
>>>>>> >> and if that doesn't work I'm attaching my sources.list that maybe
>>>>>> you can
>>>>>> >> try.
>>>>>> >> Good luck and keep us posted.
>>>>>> >> On Thu, Mar 19, 2015 at 11:51 AM, Todd Pals <tpalshadow at gmail.com>
>>>>>> wrote:
>>>>>> >>> I do get an error:
>>>>>> >>> Fetched 2,606 kB in 18s (138 kB/s)
>>>>>> >>> W: Failed to fetch
>>>>>> >>> http://dl.google.com/linux/chrome/deb/dists/stable/main/bina
>>>>>> ry-amd64/Packages
>>>>>> >>>  403  Forbidden [IP: 74.125.196.136 80]
>>>>>> >>> W: Failed to fetch
>>>>>> ry-i386/Packages
>>>>>> >>> E: Some index files failed to download. They have been ignored,
>>>>>> or old
>>>>>> >>> ones used instead.
>>>>>> >>> Here are the contents of sources.list:
>>>>>> >>> #deb cdrom:[Ubuntu 14.04.2 LTS _Trusty Tahr_ - Release amd64
>>>>>> >>> (20150218.1)]/ trus
>>>>>> >>> ty main restricted
>>>>>> >>> # See http://help.ubuntu.com/community/UpgradeNotes for how to
>>>>>> upgrade to
>>>>>> >>> # newer versions of the distribution.
>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main
>>>>>> restricted
>>>>>> >>> ## Major bug fix updates produced after the final release of the
>>>>>> >>> ## distribution.
>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>>>>> restricted
>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>>>>> >>> restricted
>>>>>> >>> ## N.B. software from this repository is ENTIRELY UNSUPPORTED by
>>>>>> the
>>>>>> >>> Ubuntu
>>>>>> >>> ## team. Also, please note that software in universe WILL NOT
>>>>>> receive any
>>>>>> >>> ## review or updates from the Ubuntu security team.
>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
>>>>>> universe
>>>>>> the
>>>>>> >>> Ubuntu
>>>>>> >>> ## team, and may not be under a free licence. Please satisfy
>>>>>> yourself as
>>>>>> >>> to
>>>>>> >>> ## your rights to use the software. Also, please note that
>>>>>> software in
>>>>>> >>> ## multiverse WILL NOT receive any review or updates from the
>>>>>> Ubuntu
>>>>>> >>> ## security team.
>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>>>>> multiverse
>>>>>> multiverse
>>>>>> >>> ## N.B. software from this repository may not have been tested as
>>>>>> >>> ## extensively as that contained in the main release, although it
>>>>>> includes
>>>>>> >>> ## newer versions of some applications which may provide useful
>>>>>> features.
>>>>>> >>> ## Also, please note that software in backports WILL NOT receive
>>>>>> any
>>>>>> >>> review
>>>>>> >>> ## or updates from the Ubuntu security team.
>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>>>>>> >>> restricted univer
>>>>>> >>> se multiverse
>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-backports
>>>>>> main
>>>>>> >>> restricted un
>>>>>> >>> iverse multiverse
>>>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security main
>>>>>> restricted
>>>>>> >>> deb-src http://security.ubuntu.com/ubuntu trusty-security main
>>>>>> restricted
>>>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security universe
>>>>>> universe
>>>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security multiverse
>>>>>> multiverse
>>>>>> >>> ## Uncomment the following two lines to add software from
>>>>>> Canonical's
>>>>>> >>> ## 'partner' repository.
>>>>>> >>> ## This software is not part of Ubuntu, but is offered by
>>>>>> Canonical and
>>>>>> >>> the
>>>>>> >>> ## respective vendors as a service to Ubuntu users.
>>>>>> >>> # deb http://archive.canonical.com/ubuntu trusty partner
>>>>>> >>> # deb-src http://archive.canonical.com/ubuntu trusty partner
>>>>>> third-party
>>>>>> >>> ## developers who want to ship their latest software.
>>>>>> >>> deb http://extras.ubuntu.com/ubuntu trusty main
>>>>>> >>> deb-src http://extras.ubuntu.com/ubuntu trusty main
>>>>>> >>> todd at todd-VirtualBox:/etc/apt$
>>>>>> >>> Thanks!
>>>>>> >>> On Thu, 19 Mar 2015 at 11:46 Dennis Baldwin <
>>>>>> >>> wrote:
>>>>>> >>>> Strange. I just did an install on 14.04 with no problems. I
>>>>>> wonder if
>>>>>> >>>> it's an issue with your sources.list. It looks like it's failing
>>>>>> here:
>>>>>> >>>> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/
>>>>>> install.sh#L107
>>>>>> >>>> Try running this directly from your command line and see if you
>>>>>> still
>>>>>> >>>> get that 403 error:
>>>>>> >>>> sudo apt-get update --assume-yes
>>>>>> >>>> If so, paste your /etc/apt/sources.list and I'll compare with
>>>>>> mine.
>>>>>> >>>> On Thu, Mar 19, 2015 at 11:31 AM, Todd Pals <
>>>>>> >>>> wrote:
>>>>>> >>>>> apt-get_get.log and sysinfo.txt are the only two files in the
>>>>>> logs
>>>>>> >>>>> directory.
>>>>>> >>>>> On Thu, 19 Mar 2015 at 11:27 Dennis Baldwin <
>>>>>> >>>>> wrote:
>>>>>> >>>>>> Hey Todd,
>>>>>> >>>>>> What about attaching apt-get_install.log? I see those 403 in
>>>>>> the
>>>>>> >>>>>> apt-get_get.log but not sure those are really the problem. The
>>>>>> >>>>>> apt-get_install should hopefully give us more info.
>>>>>> >>>>>> Dennis
>>>>>> >>>>>> On Thu, Mar 19, 2015 at 8:42 AM, Todd Pals <
>>>>>> >>>>>> wrote:
>>>>>> >>>>>>> Here are the logs, thanks!
>>>>>> >>>>>>> On Wed, 18 Mar 2015 at 21:56 Alex Mandel <
>>>>>> >>>>>>> wrote:
>>>>>> >>>>>>>> Yup check the log, if you're install stopped at the Updating
>>>>>> step
>>>>>> >>>>>>>> then
>>>>>> >>>>>>>> there was a failure really early on installing packages via
>>>>>> apt-get.
>>>>>> >>>>>>>> FYI, the install.sh is really readable.
>>>>>> >>>>>>>> -Alex
>>>>>> >>>>>>>> On 03/18/2015 07:16 PM, Blake Girardot wrote:
>>>>>> >>>>>>>>> Hi,
>>>>>> >>>>>>>>> There should be a logs folder in the install directory. Can
>>>>>> you
>>>>>> >>>>>>>> open
>>>>>> >>>>>>>>> file with the latest last modification time and put the
>>>>>> contents
>>>>>> >>>>>>>> of that
>>>>>> >>>>>>>>> log in an email?
>>>>>> >>>>>>>>> Cheers,
>>>>>> >>>>>>>>> Blake
>>>>>> >>>>>>>>> On 3/19/2015 3:06 AM, Todd Pals wrote:
>>>>>> >>>>>>>>>> First let me apologize for incorrectly posting to the
>>>>>> github
>>>>>> >>>>>>>> earlier
>>>>>> >>>>>>>>>> today, I'm sorry about that.
>>>>>> >>>>>>>>>> I am new to the Linux, so if I'm completely dumb in what
>>>>>> I'm
>>>>>> >>>>>>>> asking,
>>>>>> >>>>>>>>>> just let me know. You won't hurt my feelings. I'm running
>>>>>> Ubuntu
>>>>>> >>>>>>>> 14.04
>>>>>> >>>>>>>>>> LTS on an Oracle VirtualBox (setup just for this).
>>>>>> >>>>>>>>>> When I run the install I get this:
>>>>>> >>>>>>>>>> todd at todd-VirtualBox:~/Documents/OpenDroneMap$ sudo
>>>>>> ./install.sh
>>>>>> >>>>>>>>>>   created by Daniel Schwarz/daniel.schwarz at topoi.org
>>>>>> >>>>>>>>>> <mailto:daniel.schwarz at topoi.org>
>>>>>> >>>>>>>>>>   released under Creative Commons/CC-BY
>>>>>> >>>>>>>>>>   Attribution
>>>>>> >>>>>>>>>>   if the script doesn't finish properly
>>>>>> >>>>>>>>>>   (i.e. it doesn't print "script finished" at the end)
>>>>>> >>>>>>>>>>   please email me the content of the logs folder
>>>>>> >>>>>>>>>> script started - Wed Mar 18 16:18:44 CDT 2015
>>>>>> >>>>>>>>>> installing required packages
>>>>>> >>>>>>>>>> - updating
>>>>>> >>>>>>>>>> And nothing seems to happen. If I try and run a set of the
>>>>>> sample
>>>>>> >>>>>>>> images
>>>>>> >>>>>>>>>> or the set that Dennis Baldwin has in his videos I get
>>>>>> this:
>>>>>> >>>>>>>>>> sh: 1: jhead: not found
>>>>>> >>>>>>>>>> no CCD width or focal length found for img_4851.jpg -
>>>>>> camera: "
>>>>>> >>>>>>>> "sh: 1:
>>>>>> >>>>>>>>>> jhead: not found
>>>>>> >>>>>>>>>> Any help would be appreciated!
>>>>>> >>>>>>>>>> -Todd
>>>>>> >>>>>>>>>> _______________________________________________
>>>>>> >>>>>>>>>> OpenDroneMap-users mailing list
>>>>>> >>>>>>>>>> OpenDroneMap-users at lists.osgeo.org
>>>>>> >>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/
>>>>>> >>>>>>>> opendronemap-users
>>>>>> opendronemap-users
>>>>>> >>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap
>>>>>> -users
>>>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150320/c252f2db/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
