[OpenDroneMap-users] Install Issue
Todd Pals
tpalshadow at gmail.com
Fri Mar 20 12:26:46 PDT 2015
OK, might have been a firewall issue here at work. I used a machine on our
guest network to manually download the parallel file and put it in the ODM
directory then kicked the install off again...fingers crossed.
On Fri, 20 Mar 2015 at 12:46 Todd Pals <tpalshadow at gmail.com> wrote:
> Is the http://ftp.gnu.org/gnu/parallel/parallel-20141022.tar.bz2 file
> supposed to be 2.6 kb or larger?
> On Fri, 20 Mar 2015 at 12:36 Dennis Baldwin <db at unmannedairlines.com>
> wrote:
>> I ran into this early on. Maybe this will help:
>> https://github.com/OpenDroneMap/OpenDroneMap/issues/7
>> Keep us posted.
>> On Fri, Mar 20, 2015 at 12:22 PM, Todd Pals <tpalshadow at gmail.com> wrote:
>>> More problems, maybe I'm not cut out for this at this point.
>>> I am trying to install it here at work and it errors out with: mv:
>>> cannot stat `parallel-20141022': No such file or directory
>>> The extract_parallel.tar.bz2.log file says:
>>> bzip2: (stdin) is not a bzip2 file.
>>> tar: Child returned status 2
>>> tar: Error is not recoverable: exiting now
>>> On Fri, 20 Mar 2015 at 00:05 Todd Pals <tpalshadow at gmail.com> wrote:
>>>> Thanks for the help everyone. I ended up creating a new machine using
>>>> 12.04 instead of 14.04, took exactly the same setups steps for 12 as I did
>>>> for 14 and everything seems to be running now. I'll give one of the test
>>>> image sets a try tomorrow.
>>>> On Thu, 19 Mar 2015 at 16:39 Todd Pals <tpalshadow at gmail.com> wrote:
>>>>> I created a brand new virtual machine and install of 14.04. I made no
>>>>> changes to the machine and now it says installing and quits. It did make
>>>>> progress as I now have an apt-get_install.log file, contents below:
>>>>> Reading package lists...
>>>>> Building dependency tree...
>>>>> Reading state information...
>>>>> gcc is already the newest version.
>>>>> perl is already the newest version.
>>>>> curl is already the newest version.
>>>>> curl set to manually installed.
>>>>> git is already the newest version.
>>>>> git set to manually installed.
>>>>> unzip is already the newest version.
>>>>> unzip set to manually installed.
>>>>> wget is already the newest version.
>>>>> wget set to manually installed.
>>>>> Some packages could not be installed. This may mean that you have
>>>>> requested an impossible situation or if you are using the unstable
>>>>> distribution that some required packages have not yet been created
>>>>> or been moved out of Incoming.
>>>>> The following information may help to resolve the situation:
>>>>> The following packages have unmet dependencies:
>>>>> libcheese-gtk23 : Depends: libclutter-gtk-1.0-0 (>= 0.91.8) but it is
>>>>> not going to be installed
>>>>> Depends: libcogl15 (>= 1.15.8) but it is not going
>>>>> to be installed
>>>>> libcheese7 : Depends: libclutter-gst-2.0-0 (>= 0.10.0) but it is not
>>>>> Depends: gstreamer1.0-clutter but it is not going to be
>>>>> installed
>>>>> libclutter-1.0-0 : Depends: libcogl-pango15 (>= 1.15.8) but it is not
>>>>> to be installed
>>>>> E: Error, pkgProblemResolver::Resolve generated breaks, this may be
>>>>> caused by held packages.
>>>>> On Thu, 19 Mar 2015 at 13:31 Stephen Mather <stephen at smathermather.com>
>>>>> wrote:
>>>>>> Vagrant repo should work. It's a little light on ram, but otherwise
>>>>>> should be functional. The name of the repo is odm_vagrant in the
>>>>>> OpenDroneMap organization.
>>>>>> On Mar 19, 2015 1:50 PM, "Alex Mandel" <tech_dev at wildintellect.com>
>>>>>> wrote:
>>>>>>> That doesn't seem right, the stock Ubuntu would not include Chrome
>>>>>>> repos. We did have a Vagrant recipe but I'm not sure thats up to
>>>>>>> date.
>>>>>>> -Alex
>>>>>>> On 03/19/2015 10:32 AM, Todd Pals wrote:
>>>>>>> > Thanks for the hints, none of that made a difference...I might
>>>>>>> wipe this
>>>>>>> > virtual machine and try again from scratch. It was a fresh
>>>>>>> install of
>>>>>>> > Ubuntu downloaded and installed soley for trying to get
>>>>>>> opendronemap to
>>>>>>> > work, so I won't be losing out on anything. I'm just using the
>>>>>>> .iso from
>>>>>>> > ubuntu.com, is there something else I should be using?
>>>>>>> > On Thu, 19 Mar 2015 at 12:02 Dennis Baldwin <
>>>>>>> db at unmannedairlines.com> wrote:
>>>>>>> >> Try this:
>>>>>>> >> https://coderwall.com/p/3n6xka/fix-apt-on-old-unsupported-ub
>>>>>>> untu-releases
>>>>>>> >> and if that doesn't work I'm attaching my sources.list that maybe
>>>>>>> you can
>>>>>>> >> try.
>>>>>>> >> Good luck and keep us posted.
>>>>>>> >> On Thu, Mar 19, 2015 at 11:51 AM, Todd Pals <tpalshadow at gmail.com>
>>>>>>> wrote:
>>>>>>> >>> I do get an error:
>>>>>>> >>> Fetched 2,606 kB in 18s (138 kB/s)
>>>>>>> >>> W: Failed to fetch
>>>>>>> >>> http://dl.google.com/linux/chrome/deb/dists/stable/main/bina
>>>>>>> ry-amd64/Packages
>>>>>>> >>> 403 Forbidden [IP: 74.125.196.136 80]
>>>>>>> >>> W: Failed to fetch
>>>>>>> ry-i386/Packages
>>>>>>> >>> E: Some index files failed to download. They have been ignored,
>>>>>>> or old
>>>>>>> >>> ones used instead.
>>>>>>> >>> Here are the contents of sources.list:
>>>>>>> >>> #deb cdrom:[Ubuntu 14.04.2 LTS _Trusty Tahr_ - Release amd64
>>>>>>> >>> (20150218.1)]/ trus
>>>>>>> >>> ty main restricted
>>>>>>> >>> # See http://help.ubuntu.com/community/UpgradeNotes for how to
>>>>>>> upgrade to
>>>>>>> >>> # newer versions of the distribution.
>>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
>>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main
>>>>>>> restricted
>>>>>>> >>> ## Major bug fix updates produced after the final release of the
>>>>>>> >>> ## distribution.
>>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>>>>>> restricted
>>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates main
>>>>>>> >>> restricted
>>>>>>> >>> ## N.B. software from this repository is ENTIRELY UNSUPPORTED by
>>>>>>> the
>>>>>>> >>> Ubuntu
>>>>>>> >>> ## team. Also, please note that software in universe WILL NOT
>>>>>>> receive any
>>>>>>> >>> ## review or updates from the Ubuntu security team.
>>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty universe
>>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
>>>>>>> universe
>>>>>>> the
>>>>>>> >>> Ubuntu
>>>>>>> >>> ## team, and may not be under a free licence. Please satisfy
>>>>>>> yourself as
>>>>>>> >>> to
>>>>>>> >>> ## your rights to use the software. Also, please note that
>>>>>>> software in
>>>>>>> >>> ## multiverse WILL NOT receive any review or updates from the
>>>>>>> Ubuntu
>>>>>>> >>> ## security team.
>>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
>>>>>>> multiverse
>>>>>>> multiverse
>>>>>>> >>> ## N.B. software from this repository may not have been tested as
>>>>>>> >>> ## extensively as that contained in the main release, although
>>>>>>> it includes
>>>>>>> >>> ## newer versions of some applications which may provide useful
>>>>>>> features.
>>>>>>> >>> ## Also, please note that software in backports WILL NOT receive
>>>>>>> any
>>>>>>> >>> review
>>>>>>> >>> ## or updates from the Ubuntu security team.
>>>>>>> >>> deb http://us.archive.ubuntu.com/ubuntu/ trusty-backports main
>>>>>>> >>> restricted univer
>>>>>>> >>> se multiverse
>>>>>>> >>> deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-backports
>>>>>>> main
>>>>>>> >>> restricted un
>>>>>>> >>> iverse multiverse
>>>>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security main
>>>>>>> restricted
>>>>>>> >>> deb-src http://security.ubuntu.com/ubuntu trusty-security main
>>>>>>> restricted
>>>>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security universe
>>>>>>> universe
>>>>>>> >>> deb http://security.ubuntu.com/ubuntu trusty-security multiverse
>>>>>>> multiverse
>>>>>>> >>> ## Uncomment the following two lines to add software from
>>>>>>> Canonical's
>>>>>>> >>> ## 'partner' repository.
>>>>>>> >>> ## This software is not part of Ubuntu, but is offered by
>>>>>>> Canonical and
>>>>>>> >>> the
>>>>>>> >>> ## respective vendors as a service to Ubuntu users.
>>>>>>> >>> # deb http://archive.canonical.com/ubuntu trusty partner
>>>>>>> >>> # deb-src http://archive.canonical.com/ubuntu trusty partner
>>>>>>> third-party
>>>>>>> >>> ## developers who want to ship their latest software.
>>>>>>> >>> deb http://extras.ubuntu.com/ubuntu trusty main
>>>>>>> >>> deb-src http://extras.ubuntu.com/ubuntu trusty main
>>>>>>> >>> todd at todd-VirtualBox:/etc/apt$
>>>>>>> >>> Thanks!
>>>>>>> >>> On Thu, 19 Mar 2015 at 11:46 Dennis Baldwin <
>>>>>>> >>> wrote:
>>>>>>> >>>> Strange. I just did an install on 14.04 with no problems. I
>>>>>>> wonder if
>>>>>>> >>>> it's an issue with your sources.list. It looks like it's
>>>>>>> failing here:
>>>>>>> >>>> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/i
>>>>>>> nstall.sh#L107
>>>>>>> >>>> Try running this directly from your command line and see if you
>>>>>>> still
>>>>>>> >>>> get that 403 error:
>>>>>>> >>>> sudo apt-get update --assume-yes
>>>>>>> >>>> If so, paste your /etc/apt/sources.list and I'll compare with
>>>>>>> mine.
>>>>>>> >>>> On Thu, Mar 19, 2015 at 11:31 AM, Todd Pals <
>>>>>>> >>>> wrote:
>>>>>>> >>>>> apt-get_get.log and sysinfo.txt are the only two files in the
>>>>>>> logs
>>>>>>> >>>>> directory.
>>>>>>> >>>>> On Thu, 19 Mar 2015 at 11:27 Dennis Baldwin <
>>>>>>> >>>>> wrote:
>>>>>>> >>>>>> Hey Todd,
>>>>>>> >>>>>> What about attaching apt-get_install.log? I see those 403 in
>>>>>>> the
>>>>>>> >>>>>> apt-get_get.log but not sure those are really the problem. The
>>>>>>> >>>>>> apt-get_install should hopefully give us more info.
>>>>>>> >>>>>> Dennis
>>>>>>> >>>>>> On Thu, Mar 19, 2015 at 8:42 AM, Todd Pals <
>>>>>>> >>>>>> wrote:
>>>>>>> >>>>>>> Here are the logs, thanks!
>>>>>>> >>>>>>> On Wed, 18 Mar 2015 at 21:56 Alex Mandel <
>>>>>>> >>>>>>> wrote:
>>>>>>> >>>>>>>> Yup check the log, if you're install stopped at the
>>>>>>> Updating step
>>>>>>> >>>>>>>> then
>>>>>>> >>>>>>>> there was a failure really early on installing packages via
>>>>>>> apt-get.
>>>>>>> >>>>>>>> FYI, the install.sh is really readable.
>>>>>>> >>>>>>>> -Alex
>>>>>>> >>>>>>>> On 03/18/2015 07:16 PM, Blake Girardot wrote:
>>>>>>> >>>>>>>>> Hi,
>>>>>>> >>>>>>>>> There should be a logs folder in the install directory.
>>>>>>> Can you
>>>>>>> >>>>>>>> open
>>>>>>> >>>>>>>>> file with the latest last modification time and put the
>>>>>>> contents
>>>>>>> >>>>>>>> of that
>>>>>>> >>>>>>>>> log in an email?
>>>>>>> >>>>>>>>> Cheers,
>>>>>>> >>>>>>>>> Blake
>>>>>>> >>>>>>>>> On 3/19/2015 3:06 AM, Todd Pals wrote:
>>>>>>> >>>>>>>>>> First let me apologize for incorrectly posting to the
>>>>>>> github
>>>>>>> >>>>>>>> earlier
>>>>>>> >>>>>>>>>> today, I'm sorry about that.
>>>>>>> >>>>>>>>>> I am new to the Linux, so if I'm completely dumb in what
>>>>>>> I'm
>>>>>>> >>>>>>>> asking,
>>>>>>> >>>>>>>>>> just let me know. You won't hurt my feelings. I'm running
>>>>>>> Ubuntu
>>>>>>> >>>>>>>> 14.04
>>>>>>> >>>>>>>>>> LTS on an Oracle VirtualBox (setup just for this).
>>>>>>> >>>>>>>>>> When I run the install I get this:
>>>>>>> >>>>>>>>>> todd at todd-VirtualBox:~/Documents/OpenDroneMap$ sudo
>>>>>>> ./install.sh
>>>>>>> >>>>>>>>>> created by Daniel Schwarz/daniel.schwarz at topoi.org
>>>>>>> >>>>>>>>>> <mailto:daniel.schwarz at topoi.org>
>>>>>>> >>>>>>>>>> released under Creative Commons/CC-BY
>>>>>>> >>>>>>>>>> Attribution
>>>>>>> >>>>>>>>>> if the script doesn't finish properly
>>>>>>> >>>>>>>>>> (i.e. it doesn't print "script finished" at the end)
>>>>>>> >>>>>>>>>> please email me the content of the logs folder
>>>>>>> >>>>>>>>>> script started - Wed Mar 18 16:18:44 CDT 2015
>>>>>>> >>>>>>>>>> installing required packages
>>>>>>> >>>>>>>>>> - updating
>>>>>>> >>>>>>>>>> And nothing seems to happen. If I try and run a set of
>>>>>>> the sample
>>>>>>> >>>>>>>> images
>>>>>>> >>>>>>>>>> or the set that Dennis Baldwin has in his videos I get
>>>>>>> this:
>>>>>>> >>>>>>>>>> sh: 1: jhead: not found
>>>>>>> >>>>>>>>>> no CCD width or focal length found for img_4851.jpg -
>>>>>>> camera: "
>>>>>>> >>>>>>>> "sh: 1:
>>>>>>> >>>>>>>>>> jhead: not found
>>>>>>> >>>>>>>>>> Any help would be appreciated!
>>>>>>> >>>>>>>>>> -Todd
>>>>>>> >>>>>>>>>> _______________________________________________
>>>>>>> >>>>>>>>>> OpenDroneMap-users mailing list
>>>>>>> >>>>>>>>>> OpenDroneMap-users at lists.osgeo.org
>>>>>>> >>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/
>>>>>>> >>>>>>>> opendronemap-users
>>>>>>> opendronemap-users
>>>>>>> >>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap
>>>>>>> -users
>>>>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150320/d211a0c5/attachment-0001.html>
More information about the OpenDroneMap-users
