[OpenDroneMap-users] Running on Fedora?
Frederic Muller fred at cm17.com
Tue Mar 24 01:18:16 PDT 2015
Ok so I got passed the missing libraries (or I think I did). The
compilation now stops at "building and installing pcl"
and the error log says:
[ 66%] Building CXX object io/CMakeFiles/pcl_io.dir/src/libpng_wrapper.cpp.o
make[2]: *** No rule to make target '/usr/lib64/libnetcdf_c++.so',
needed by 'lib/libpcl_io.so.1.7.2'.  Stop.
CMakeFiles/Makefile2:356: recipe for target
'io/CMakeFiles/pcl_io.dir/all' failed
make[1]: *** [io/CMakeFiles/pcl_io.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
What could that be? I'll continue searching and revert back to the list
if I find anything.
Thank you.
Fred
On 03/24/2015 01:23 PM, Frederic Muller wrote:
> Sorry for the noise, that was just a missing package(s).
> I'll continue and try to do deeper searches before posting.
> Fred
> On 03/24/2015 01:09 PM, Frederic Muller wrote:
>> Hi!
>> So I've finally started. There was a package missing to allow
>> compilation and then everything compiles well until cmvs/pmvs. The log
>> file tells me there is a file missing:
>> Documents/OpenDroneMap/include
>> -I/home/fred/Documents/OpenDroneMap/include/metisLib/ -fopenmp
>> -DNUMBITS=64  ../base/cmvs/graclus.cc
>> g++ -o genOption genOption.cc
>> In file included from ../base/pmvs/seed.cc:5:0:
>> ../base/pmvs/seed.h:4:32: fatal error: boost/shared_ptr.hpp: No such
>> file or directory
>>  #include <boost/shared_ptr.hpp>
>> Any idea what that could be?
>> Thank you.
>> Fred
>> On 03/21/2015 10:10 PM, Stephen Mather wrote:
>>> Hi Fred,
>>> As far as I know, no one has tried. Good luck and let us know how it goes!
>>> Best,
>>> Steve
>>> On Mar 21, 2015 4:44 AM, "Frederic Muller" <fred at cm17.com
>>> <mailto:fred at cm17.com>> wrote:
>>>     Hi!
>>>     Out of curiosity, has anyone tried to run Open Drone Map on Fedora? I'm
>>>     thinking to give it a try so I guess I'll have to update the install
>>>     script, make sure that the packages to install have the proper names.
>>>     Anything else I should pay attention to?
>>>     Thank you.
>>>     Fred
>>>     _______________________________________________
>>>     OpenDroneMap-users mailing list
>>>     OpenDroneMap-users at lists.osgeo.org
>>>     <mailto:OpenDroneMap-users at lists.osgeo.org>
>>>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
