[OpenDroneMap-users] Running on Fedora?
Frederic Muller fred at cm17.com
Tue Mar 24 04:10:39 PDT 2015
Just fixed that problem: it was a wrong library installed (libproj-devel
insteas of proj-devel). On to the new issue now...
Fred
On 03/24/2015 03:18 PM, Frederic Muller wrote:
> Ok so I got passed the missing libraries (or I think I did). The
> compilation now stops at "building and installing pcl"
> and the error log says:
> [ 66%] Building CXX object io/CMakeFiles/pcl_io.dir/src/libpng_wrapper.cpp.o
> make[2]: *** No rule to make target '/usr/lib64/libnetcdf_c++.so',
> needed by 'lib/libpcl_io.so.1.7.2'.  Stop.
> CMakeFiles/Makefile2:356: recipe for target
> 'io/CMakeFiles/pcl_io.dir/all' failed
> make[1]: *** [io/CMakeFiles/pcl_io.dir/all] Error 2
> Makefile:127: recipe for target 'all' failed
> make: *** [all] Error 2
> What could that be? I'll continue searching and revert back to the list
> if I find anything.
> Thank you.
> Fred
> On 03/24/2015 01:23 PM, Frederic Muller wrote:
>> Sorry for the noise, that was just a missing package(s).
>> I'll continue and try to do deeper searches before posting.
>> Fred
>> On 03/24/2015 01:09 PM, Frederic Muller wrote:
>>> Hi!
>>> So I've finally started. There was a package missing to allow
>>> compilation and then everything compiles well until cmvs/pmvs. The log
>>> file tells me there is a file missing:
>>> Documents/OpenDroneMap/include
>>> -I/home/fred/Documents/OpenDroneMap/include/metisLib/ -fopenmp
>>> -DNUMBITS=64  ../base/cmvs/graclus.cc
>>> g++ -o genOption genOption.cc
>>> In file included from ../base/pmvs/seed.cc:5:0:
>>> ../base/pmvs/seed.h:4:32: fatal error: boost/shared_ptr.hpp: No such
>>> file or directory
>>>  #include <boost/shared_ptr.hpp>
>>> Any idea what that could be?
>>> Thank you.
>>> Fred
>>> On 03/21/2015 10:10 PM, Stephen Mather wrote:
>>>> Hi Fred,
>>>> As far as I know, no one has tried. Good luck and let us know how it goes!
>>>> Best,
>>>> Steve
>>>> On Mar 21, 2015 4:44 AM, "Frederic Muller" <fred at cm17.com
>>>> <mailto:fred at cm17.com>> wrote:
>>>>     Hi!
>>>>     Out of curiosity, has anyone tried to run Open Drone Map on Fedora? I'm
>>>>     thinking to give it a try so I guess I'll have to update the install
>>>>     script, make sure that the packages to install have the proper names.
>>>>     Anything else I should pay attention to?
>>>>     Thank you.
>>>>     Fred
>>>>     _______________________________________________
>>>>     OpenDroneMap-users mailing list
>>>>     OpenDroneMap-users at lists.osgeo.org
>>>>     <mailto:OpenDroneMap-users at lists.osgeo.org>
>>>>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
More information about the OpenDroneMap-users mailing list
