[OpenDroneMap-users] OpenDroneMap optimization questions
Dennis Baldwin
db at unmannedairlines.com
Tue Mar 31 19:11:51 PDT 2015
Danning,
All of those "parts" are necessary to build the orthophoto. You could
always modify the run script to remove those files at the end if you'd
like. But disk space is cheap nowadays and 2 GB shouldn't cause you too
much trouble. How did your orthophoto turn out? Can you share a link so we
can see it?
Dennis
On Sun, Mar 29, 2015 at 4:40 PM, Danning Sun <danning at umich.edu> wrote:
> Hi Dennis,
> We noticed that the final output Involve other parts apart from a png
> picture including the image stitching results. We are wondering if there is
> any way that we could prevent them from outputting? Since the total size of
> them is around 2 GB.
> Thanks!
> Danning
> On Thursday, March 26, 2015, Dennis Baldwin <db at unmannedairlines.com>
> wrote:
>> What are your current VM specs and what is your sponsor's requirement
>> regarding processing speed? I have a sample set of about 90 images that I
>> use to test the latest ODM updates and it takes me a little over an hour on
>> an 8 GB Ubuntu 64 bit VM running on Amazon.
>> On Thu, Mar 26, 2015 at 11:00 AM, En Li <enli at umich.edu> wrote:
>>> Hey Guys:
>>> I hope you are all doing well! My name is David Li, I am computer
>>> science major from the University of Michigan. First I want to thank you
>>> all for your contribution to this project. Currently, my team and I are
>>> trying to enable a drone to fly over the crops of mid to large farm owners
>>> to accomplish crop surveillance for them. We tried the opendronemap on VM.
>>> We tried to run ODM with around 70 photos and it took more than an hour to
>>> finish. While we are impressed by the quality of the resulting picture, our
>>> sponsor has pointed out the image processing process was a little too long.
>>> We were wondering if there are ways we could reduce this time so we are
>>> closer to our sponsor's requirement. Any help would be wonderful! Thank
>>> you so much!
>>> En Li
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
> Thanks for consideration.
> Best,
> Danning Sun
> *College of Engineering, University of Michigan*
> *B.S.E **Aerospace **Engineering 16'*
> *UM-SJTU Joint Institute, Shanghai Jiao Tong University*
> *B.S.E **Mechanical** Engineering 16'*
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150331/d8c8d191/attachment.html>
More information about the OpenDroneMap-users
