[OpenDroneMap-users] Error using OpenDroneMap
Willem Buitendyk willem at pcfish.ca
Tue May 12 11:05:44 PDT 2015
Hi there,
Ubuntu 14.04.   I’ve installed the latest opendronemap.  When I use the run.pl command everything seems to work up until I receive the following error:
  - running meshing - Tue May 12 10:53:27 PDT 2015
[pcl::KdTreeFLANN::setInputCloud] Cannot create a KDTree with an empty input cloud!
[WARNING] Initial residual too low: 0 < 0.000001
[pcl::io::savePLYFile] Input point cloud has no data!
Error in OdmMeshing:
Error when saving mesh to file:
/home/willem/house_survey/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
For more detailed information, see log file.
quitting cause:
	"/home/willem/OpenDroneMap/bin/odm_meshing" -inputFile /home/willem/house_survey/reconstruction-with-image-size-2400-results/option-0000.ply -outputFile /home/willem/house_survey/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply -logFile /home/willem/house_survey/reconstruction-with-image-size-2400/odm_meshing/odm_meshing_log.txt -maxVertexCount 100000 -octreeDepth 9 -samplesPerNode 1
returned with code 256
willem at ubuntu:~/house_survey$
Willem Buitendyk
More information about the OpenDroneMap-users mailing list
