[OpenDroneMap-users] Error using OpenDroneMap
Willem Buitendyk
willem at pcfish.ca
Tue May 12 12:49:53 PDT 2015
I should note that this was originally on ubuntu running on parallels. This time I tried it on a dedicated server running ubuntu 14.04 and received the same error. There appears to be something wrong with the toolchain.
My process was:
git clone https://github.com/OpenDroneMap/OpenDroneMap.git <https://github.com/OpenDroneMap/OpenDroneMap.git>
install.sh
~/OpenDroneMap/./run.pl from within my folder located at ~/house_survey
Willem Buitendyk
> On May 12, 2015, at 11:05 AM, Willem Buitendyk <willem at pcfish.ca> wrote:
> Hi there,
> Ubuntu 14.04. I’ve installed the latest opendronemap. When I use the run.pl command everything seems to work up until I receive the following error:
> - running meshing - Tue May 12 10:53:27 PDT 2015
> [pcl::KdTreeFLANN::setInputCloud] Cannot create a KDTree with an empty input cloud!
> [WARNING] Initial residual too low: 0 < 0.000001
> [pcl::io::savePLYFile] Input point cloud has no data!
> Error in OdmMeshing:
> Error when saving mesh to file:
> /home/willem/house_survey/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply
> For more detailed information, see log file.
> quitting cause:
> "/home/willem/OpenDroneMap/bin/odm_meshing" -inputFile /home/willem/house_survey/reconstruction-with-image-size-2400-results/option-0000.ply -outputFile /home/willem/house_survey/reconstruction-with-image-size-2400-results/odm_mesh-0000.ply -logFile /home/willem/house_survey/reconstruction-with-image-size-2400/odm_meshing/odm_meshing_log.txt -maxVertexCount 100000 -octreeDepth 9 -samplesPerNode 1
> returned with code 256
> willem at ubuntu:~/house_survey$
> Willem Buitendyk
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150512/ce162e77/attachment.html>
More information about the OpenDroneMap-users
