[OpenDroneMap-users] Segmentation fault
Gregor MacLennan gmaclennan+odm at digital-democracy.org
Wed May 13 18:37:06 PDT 2015
I am getting a segmentation fault when trying to process 562 images under
the default settings on a 16GB 8-core virtual machine. Any ideas what is
wrong? Other log files I should post?
Segmentation fault (core dumped)
.......parallel: Starting no more jobs. Waiting for 8 jobs to finish. This
job failed:
echo -n "." && touch
"/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" &&
"/root/marudi/../OpenDroneMap/bin/KeyMatch"
"/root/marudi/reconstruction-with-image-size-2400/G0020035_geotag.key"
"/root/marudi/reconstruction-with-image-size-2400/G0020363_geotag.key"
"/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" 0.6 2
quitting cause:
"/root/marudi/../OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0 <
"/root/marudi/reconstruction-with-image-size-2400/_matches_jobs.templist.txt"
returned with code 35584
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150513/d119cedc/attachment.html>
More information about the OpenDroneMap-users mailing list
