[OpenDroneMap-users] Segmentation fault
Stephen Mather
stephen at smathermather.com
Thu May 14 08:24:07 PDT 2015
Hi Gregor,
This looks like you don't have enough RAM relative to the number of cores.
Try using just 4 of your cores as a start.
https://github.com/OpenDroneMap/OpenDroneMap/issues/28
https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L478
Cheers,
Best,
Steve
On Wed, May 13, 2015 at 9:37 PM, Gregor MacLennan <
gmaclennan+odm at digital-democracy.org> wrote:
> I am getting a segmentation fault when trying to process 562 images under
> the default settings on a 16GB 8-core virtual machine. Any ideas what is
> wrong? Other log files I should post?
> Segmentation fault (core dumped)
> .......parallel: Starting no more jobs. Waiting for 8 jobs to finish. This
> job failed:
> echo -n "." && touch
> "/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" &&
> "/root/marudi/../OpenDroneMap/bin/KeyMatch"
> "/root/marudi/reconstruction-with-image-size-2400/G0020035_geotag.key"
> "/root/marudi/reconstruction-with-image-size-2400/G0020363_geotag.key"
> "/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" 0.6 2
> quitting cause:
> "/root/marudi/../OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0 <
> "/root/marudi/reconstruction-with-image-size-2400/_matches_jobs.templist.txt"
> returned with code 35584
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150514/186f7f71/attachment.html>
More information about the OpenDroneMap-users
