[OpenDroneMap-users] Segmentation fault
Dennis Baldwin db at unmannedairlines.com
Thu May 14 08:45:48 PDT 2015
Gregor,
Make sure you change this line:
https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L572
Steve pointed you to a link that I posted referencing an older run script.
Modifying the line above should do the trick.
Let us know if you run into any problems.
Dennis
On Thu, May 14, 2015 at 10:24 AM, Stephen Mather <stephen at smathermather.com>
wrote:
> Hi Gregor,
> This looks like you don't have enough RAM relative to the number of cores.
> Try using just 4 of your cores as a start.
> https://github.com/OpenDroneMap/OpenDroneMap/issues/28
> https://github.com/OpenDroneMap/OpenDroneMap/blob/gh-pages/run.pl#L478
> Cheers,
> Best,
> Steve
> On Wed, May 13, 2015 at 9:37 PM, Gregor MacLennan <
> gmaclennan+odm at digital-democracy.org> wrote:
>> I am getting a segmentation fault when trying to process 562 images under
>> the default settings on a 16GB 8-core virtual machine. Any ideas what is
>> wrong? Other log files I should post?
>> Segmentation fault (core dumped)
>> .......parallel: Starting no more jobs. Waiting for 8 jobs to finish.
>> This job failed:
>> echo -n "." && touch
>> "/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" &&
>> "/root/marudi/../OpenDroneMap/bin/KeyMatch"
>> "/root/marudi/reconstruction-with-image-size-2400/G0020035_geotag.key"
>> "/root/marudi/reconstruction-with-image-size-2400/G0020363_geotag.key"
>> "/root/marudi/reconstruction-with-image-size-2400/matches/1-329.txt" 0.6 2
>> quitting cause:
>> "/root/marudi/../OpenDroneMap/bin/parallel" --halt-on-error 1 -j+0 <
>> "/root/marudi/reconstruction-with-image-size-2400/_matches_jobs.templist.txt"
>> returned with code 35584
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150514/68e0febc/attachment.html>
More information about the OpenDroneMap-users mailing list
